serious stuff - serious fo sure Read it now !!!
- RV4ker (RIP)
Re: serious stuff - serious fo sure Read it now !!!
1:500K map
Looks like only the eastern area is outside and a small section on West? (I don't know the area at all)
- RV4ker (RIP)
1:250K paints a different picture... (just for some balance)
- RV4ker (RIP)
Wonder which one is "right".
Fact remains. If the papgooiers "file" a complaint you have a real problem....
Just my 2c....
I like looking at low flying aeries
Just my 2c....
- Dish
Moer but we have debated this topic a number of times now...
RV9
DISH
DISH
Moer but we have debated this topic a number of times now...![]()
Yes, but we like it a-lot
CAA must stop making tea-time rules. If it is not written into law it is not law.
Common law would be that the 1:250 map will over-ride the 1:500 map for obvious reasons. In construction law a detail drawing will always over-ride a general floorplan. Why else would the map creators have created a 1: 250 ? To avoid "gray area" debates of course.
It is clear that the Bronkies waterline to water is not a reserve, but the landline to land is.
Roel Jansen
ZU-IAR powered by BMW 1200
- Tumbleweed
Now the pap gooiers should go for tea and explain why they're fishing in a reserve.
So saam met die tee en al hoor ek daar was n insident in die noorde die naweek - klink amper soos n traaik sonner n pilot of sonner n flerk - weet iemand iets van dit - wonner net of die tee suipers in kennis gestel is of hoe ,
Willempie
Willempie
- Rudix
I was wondering about that......Tumbleweed wrote:Now the pap gooiers should go for tea and explain why they're fishing in a reserve.
- Rudix
Dit was sonner 'n vlerk of 'n pilotwitwillem wrote:So saam met die tee en al hoor ek daar was n insident in die noorde die naweek - klink amper soos n traaik sonner n pilot of sonner n flerk - weet iemand iets van dit - wonner net of die tee suipers in kennis gestel is of hoe ,
Willempie
Jis dit raak rof innie noorde - hoe vlie jy sonner n flerk of sonner n pilot ??
Rudix weet jy meer - lat ons hoor wat die manne anvang ?
willempie
willempie
- Rudix
Jy vlieg maar baie laag soos 'n grondvoelwitwillem wrote:Jis dit raak rof innie noorde - hoe vlie jy sonner n flerk of sonner n pilot ??
willempie
Nee, weet nie veel meer nie, net dat "iemand" aan die trike gewerk het, toe die engin gestart het wat ongelukkig full throttle was, en dit sonder die vlerk....
Niemand het seer gekry nie
Rudix,
Check the posting on Accidents and Incident by Dawid.
Caught a dream............
Windlass Aquilla
Thunderbird MKII
Savannah VG
Windlass Aquilla
Thunderbird MKII
Savannah VG
Not so obvious. I would enter a suggestion that the map that you are meant to have on board would be the one used in determining if you overstepped a boundary. If I recall correctly - it is law to have a 1:1 000 000 aero map on board of the area you are flying.kloot piloot wrote:Common law would be that the 1:250 map will over-ride the 1:500 map for obvious reasons.
