Re: Challanger II, long wing undercarriage cables.
Use this topic if you are in the market for something
RSS
Postby RSS » Mon Apr 17, 2017 1:40 pm
Help Needed, Had a bit of a hard landing and both undercarriage cables broke. On inspection it appears that these are Stainless Steel, which to my knowledge is incorrect. After landing taxied quite a distance to clear the runway and only noticed the cable problem when I climbed out. So gear is all still in the wright place and appears no other damage.I have searched to find out the cable length, center to center, but to no avail, so I hope that there is someone out there whom can help. I need to get 2 new cables manufacture before 21st April so that I can fit and fly back to home base over the weekend. BTW these are not the drag cables, the two torsion cables between the legs. Look forward to hearing from someone. Regards
falconp1
Postby falconp1 » Wed Jul 05, 2017 7:33 am
Hi RSS.
Did you eventually come right with the cables.
Freddie
ZS-WVD CONDOR
ZU-CIW Challenger 11
freddievanrooyen@yahoo.com
