Wanted fuel flow transmitter
Use this topic if you are in the market for something
Xtra
Postby Xtra » Tue Nov 25, 2014 6:15 pm
Hi
Fuel flow tx wanted, p/n 508-2704 with 2mm jet.
pm or 0719671065 puff
ZULU1
Re: Wanted fuel flow transmitter
Postby ZULU1 » Tue Nov 25, 2014 8:31 pm
Try RS Components, that part number sticks out like a dogs balls. Its a liquid flow device if not mistaken its a reference voltage output. Probabaly 0,5 to 24 volts and will be given a value in litres per minute depending on fuel flow which will be converted to a readout of some kind. Either in hex or binary. Or a straight linear reference.
Go to RS components website, type in the part number and it will advise of the device in question. I think in this country its RS.co.za or similar. By default are Rs are expensive.
If you fail, next choice will be Farnells but you will require the input parameters to source a suitable equivalent, then Newark, Mouser, Digi Key and so on.
I bet its RS..
