Autolube
Use this topic if you are in the market for something
Delta
Slow starter
Autolube
Postby Delta » Sun Jun 15, 2014 8:24 am
Would like to retro fit autolube to a 582, is this possible?
Does anybody have all the bits for sale?
Also need single radiator for 582 pusher +_ 300x400mm
Mark
Leprachaun
Re: Autolube
Postby Leprachaun » Tue Jun 17, 2014 9:34 am
Any thing is possible , if you think you can , or you think you cant , YOURE ALWAYS RIGHT >
Any 582 can take the normal auto lube , I have rune one engine 1623 hour never missed a beat , Presemtly my Trike has just had its 300 hr decoke , not aproblem whatsover , You need the pump, pipe filter and tank with mounting brackets for the Aquilla (rear ) radiator alternatively the Brackets wich fit onto the engine , these tend to break due to vibrations . You may have to change the plate where the carbs fit on , cost last one purchased was R1400,00 ex Comet , there are many pumps lying in hangars advertise and you will get , Call me should you need more info Alex 0825688635 Leprachaun (^^)
