does any one maybe have a right hand pusher=puller Pprop/similar anything 70"to 72" with 44"- 47" pitch that I can test and hopefully buy on my UL Power 350i engine? have a loan one with 52" pitch but it is too coarse. Bolt pitch 100mm
I am based in Hartbeespoort but will collect basically anywhere in country!?
Deon
Wanted Pprop
Re: Wanted Pprop
Now, there are several options for your engine:
1) 2-bladed wooden propeller diameter from 1524 to 1720 mm. We achieved to reduce noise even when the diameter of 1720 mm. In this thrust is considerably greater than 1524 mm. Steel edge protection, strengthening of fiberglass.
2) 3-bladed propeller with scimitar-shaped carbon fiber blades with a diameter 1644 mm. Maximum thrust minimum noise, the complete absence of vibrations.
- KFA
Re: Wanted Pprop
Hi Deon, Het jy die UL 350 wat 118hp is? Indien wel kan jy die Jabiru/Camit prop gebruik wat ons op die Safari gebruik. Daar is geen manier wat die UL engine n 70 of 72" prop gaan trek en nie gaan supersonic gaan nie. Dit gese, ek twyfel baie sterk of die engine dit enigsinds gaan regkry om die 70 of 72 by daai sped uit te bring. Jou ideaal sal wees om so 2900 -3000 op take off te kry en so 2700-2900 te cruise. Ek vat nou n ingeligte raai maar jou prop gaan omtrent n 64x42 moet wees. Jy kan dalk op n 66 begin maar jou rpm gaan net by so 2600-2700 uitkom en dit is te laag. As jy op 66 begin kan jy hom 1 duim op n slag sny tot die rpm reg is.
