Mint Condition 912UL Aquilla 2
R120 000-00
Tel: 084 701 4988
wvbosch@gmail.com
Hangered @ Crosswinds
1. New Aquilla 2 Wing. Not recovered only, [b complete brand new wing[/b] (18.5hrs)
2. Replaced all nuts and bolts on the trike itself. All new
3. 912UL upgraded piston kit to 95HP. Powerful!
4. Complete New carb kits installed, including new floats etc etc. R6000-00
5. New facet fuel pump.
6. Gearbox serviced 13hrs back
7. Meticulously maintained. (Shell Advanced AX7, new fuel and oil filter, new spark plugs, full maintenance done annually) Did it at 13.5hrs last year, so oil gets replaced often. FAR from required 50hrs.
8. Stratomaster Extreme X, master instrument. EGT, CHT, flight time, altitude, hobbs, maintenance meter, date and time, aircraft registration, altitude alarm, speed alarms etc etc. See link below for full manual.
9. 3 x new tyres.
10. Cruise 60 knots
11. A21 icom radio + 2 x headset + Buzzcom
12. Winglets
13. New fuel lines installed, new plug suppressors, redone all aircraft wiring
14. Trike cover
15. Red and white strobe lights
16. Full dual controls. Steering, throttle and control bars.
Engine and air-frame hrs - 1400
Engine - 912UL Upgraded to 95HP!
Valid FRESH ATF expires - 18 May 2018
For original pictures look here: https://1drv.ms/f/s!AsoZErDI0yCk6g4FZdGFwEMRdlGj
Full YouTube Channel to see her in action: http://www.youtube.com/wvbosch
Listen to her purrrrr
youtu.be/
youtu.be/
