Cheetah bargain R290K neg. with fresh ATF and new Trylam.
Shumba
Postby Shumba » Mon Jul 01, 2013 10:12 am
Cheetah XLS by Frigate Air, s/n CH068
Jabiru 85 HP engine and P-PROP, TT 721 hrs and counting
Valid fresh ATF to be issued for new owner, also for night operations for rated pilots.
SHE IS AT THE FACTORY FOR THE TOTAL RE-COVER AND THE ANNUAL INSPECTION. IF YOU ARE QUICK YOU CAN PICK YOU OWN COLORS.
Extensively equipped, based at FAWA.
ALT, ASI, ROC, Slip, OAT, RPM, Compass, Volts, 4xCHT, Oil Temp/Press, A200 VHF, Lowrance 600 GPS.
Nav, Landing, inst lights, Bagage nets, Spats, Overhead sun visor ect, Vortex generators.
Orange/White with Black and Silver trim.
R290 000-00 no Vat including the new ATF and re-cover with new Trylam in white only.
Pieter 081 510 4468
pieterhvd@gmail.com
Triker
Re: Cheetah F XLS for sale.
Postby Triker » Mon Jul 01, 2013 6:13 pm
You should be able to resize the photos.
Photos will enhance the sales process so much more
Shumba
Postby Shumba » Tue Jul 02, 2013 2:12 pm
Please people, can you respond directly to pieterhvd@gmail.com and I shall send photos.
Microlighters only allow 100KiB to be transmitted.
Postby Tailspin » Tue Jul 02, 2013 4:00 pm
Hey Guys
Here are Pics as Requested.
Shumba
Re: Cheetah F XLS for sale. Offers?
Postby Shumba » Thu Aug 01, 2013 8:52 pm
Still available.
micromed
Postby micromed » Fri Aug 02, 2013 11:46 am
The panel shown is not legal for night rated VFR operations. AH, DI and Turn and slip or similar instruments are lacking.
Shumba
Re: Cheetah F XLS. Temp. withdrawn for maintenance.
Postby Shumba » Sat Aug 03, 2013 2:16 pm
VFR applies to day and night operations and therefore you don't need any IF instrumentation. If you need to rely on an AH,DI and turn coordinator without visual outside reference you are in IFR conditions, day or night and will propably die shortly if not IF rated and very competent, especially in an LSA. The most important instrument in any aircraft is the one between the pilot's ears.
ZU-EGY is rated for day/night VFR operations with the current equipment list, granted the pilot has a PPL with night rating.
Triker
Postby Triker » Sat Aug 03, 2013 3:41 pm
Reason for selling?
Shumba
Postby Shumba » Wed Sep 04, 2013 8:25 pm
Hi you all,
selling to make space for the new plane which is on short finals.
Lassie
Postby Lassie » Thu Sep 05, 2013 2:17 pm
What is your cruise speed and feulburn with the Jabi motor?
Shumba
Postby Shumba » Thu Sep 05, 2013 5:58 pm
Average fuel burn overall 15 l/h
Cruise @ 80 mph @ 3000 rpm - 15 l/h
Hi speed cruise @ 90 mph @ 3200 rpm - 18 l/h
Full throttle @ 3300 rpm will burn 21 l/h for 95 - 100 mph.
P-prop 60" x 34" pitch.
Shumba
Re: Cheetah F XLS for sale, offers !!
Postby Shumba » Tue Dec 17, 2013 6:07 pm
Fresh ATF till Dec 2014.
Postby John Boucher » Wed Dec 25, 2013 5:46 pm
Cheetah bump ;-)
Shumba
Postby Shumba » Tue Jan 21, 2014 6:06 pm
Still available, any reasonable offers.
Shumba
Re: Cheetah for sale, price reduced or offers ??
Postby Shumba » Sat Mar 01, 2014 12:00 pm
Bump
