Cobra with Toyota Yaris 1NZ motor :
JACO
Re: Cobra with Toyota Yaris 1NZ motor :
Postby JACO » Wed May 05, 2010 9:07 pm
Hi Kallie,
On the ECU: As it was an Imported engine, the loom was part of the engine so we used the existing plugs and sensors to make our own loom to connect to the after market ecu. With additional relays and fuse boxes.
Engine Mounts: Pipe bending we did our self. Had welding done by Argon Arc coded welder and then had it heat stress re leaved by a specialist.
Belt Drive: Very good idea, but couldn't get the parts we needed. (At the time of investigation we decided that the Gates Poly Chain Carbon belt and pulley system was the best on the market, they realised we wanted to use it on a Microlite and refused us any further assistance as it is against their policy to allow any of their products to be used on any aircraft) :? :? ($$) ($$)
Cheers.
Postby Boet » Fri May 07, 2010 6:19 am
Jou gearbox al geland?? vhpy
JACO
Postby JACO » Sat May 08, 2010 5:30 pm
My Gearbox het toe uiteindelik gekom! :lol: :lol:
Nou moet ons net 'n paar gate boor, paswerk doen, prop aanbring en die groot toetse en instellings kan begin. Jippie !!
Die bou kwaliteit lyk baie goed en stewig. Afwerking bietjie rof, maar akkuraat.
Wat se olie sal jy nou aanbeveel Boet. Hoef toe geen verdere invoer belasting te betaal nie. Net R25,00 posgeld !
Wat 'n Bargain !! R10 500,00 vhpy
Jammer vir die donker foto.
Sal in die' week rondjaag op die aanloopbaan, dis verseker. (-) (-)
JACO
Postby JACO » Sat May 08, 2010 5:53 pm
Interesting Story
This Cobra was in an accident without leaving the ground.
It seems the pilot could not get it started while being seated.
He got out to look for any clues, tried again when it started at high revs.
Trike took off, at high speed, injured the pilot and went through a prefab wall with lots of damage.
Now, a year later, when we dismantled the craft we found that the choke and throttle was the wrong side around!
This could certainly have caused the accident!!!!! :shock: :shock:
Be Careful out there!
With some mulas later it now looks like this. Almost ready to fly.
Happy flying and safe landings.
Postby Boet » Sat May 08, 2010 7:45 pm
(^^) (^^) (^^) (^^) Wat is die gear ratio? 50w80EP ratolie. Maak seker jou chouk sit oppie regte plek. :lol: Jaa, so n trike maak groot akkies as hy so weghol. Self het jare der jare gelede een gevang wat so "weggekom" het. maar die is n laaaang en interessante storie wat laans n braaivuur oor n koue vertel word. :wink:
JACO
Postby JACO » Thu May 13, 2010 9:16 pm
Gearbox fitted, at last vhpy vhpy vhpy vhpy vhpy
Very simple design. Had it running for some 10 minutes before adding the Warpdrive 70" prop
and set at 10 Degrees for initial testing. Now the engine is working with lots of thrust!
Very low vibrations, slightly noisy as can be expected from straight cut gears with low running temps.
We'll do some minor fiddling before taking it to have the "dino" done.
After that: serious testing. Here is a picture after fitment. Not sure about the air filter yet.
ystervark7
Postby ystervark7 » Thu May 13, 2010 9:30 pm
Great Jaco!!
The gearbox looks very interesting - smaller than what I would have guessed.
I do not think that the dominant noise will be the gearbox, it is nearly always the propeller when you fly.
Keep up the good work!!
Postby Boet » Thu May 13, 2010 11:12 pm
Dis baie mooi en netjies. Maak net seker daai air cleaner is bleddie goed vas!! Hou ons op hoogte. vhpy
Postby John Boucher » Fri May 14, 2010 8:58 am
Nee donner... daardie "pancake-filter" laat die ding lyk soos 'n ou Ford Cortina :lol:
Have to agree with boet on maak seker hy is vas. Would look more the part if you did some tooling there and fitted an intake much to the likes of what the Turbo crazy guys fit. Would then be forward facing and you can fit a K&N performance filter! :idea:
ps I also just wanted to say something.... :wink:
Massimo
Postby Massimo » Fri May 14, 2010 10:13 am
John Boucher wrote:Nee donner... daardie "pancake-filter" laat die ding lyk soos 'n ou Ford Cortina :lol:
Agree, change that FILTER -xX -0< , The rest looks great, well done.
Bullseye
Postby Bullseye » Tue May 18, 2010 9:52 am
Wat het jou hele enjin projek jou uitgewek???? en hoeveel HP is hy?
The Sky is not my limit, it is my playground!!!
Dreman55
Postby Dreman55 » Tue May 18, 2010 11:09 am
Agree with the filter, yo have done so much work, why not make a decent forward facing intake and benefit from a ram air scenario. Will be worth a good few Hp.
HENNING JOHAN
Postby HENNING JOHAN » Tue May 25, 2010 7:45 pm
Hallo,Jaco!Ons het sondag op rand gepraat van die trike met die Yaris motor.Dit is great!Hoeveel HP maak dit by die dyno?Sal like om so n motor op my scout te sit.Ek is moeg vir die ratax motor!2 piston R4200! (**)
JACO
Postby JACO » Tue May 25, 2010 9:11 pm
Dankie Boet vir die PM.
Ons het vandag die engine laat tune. Goeie resultate gekry. Start nou maklik, loop baie glad, effens ryk op lambda.
VVTi maak oop op 4200. Thrust = 195 kg @ 5400 rpm. Kon natuurlik nie die kW of HP kry nie aangesien die wiele nie saam wou draai nie :lol: :lol: :lol: (Engine Dino is nodig vir die' toetsie en ons kon niemand kry wat dit wou doen nie!)
Ons het ook 'n standaard 582 Rattax Blue Top onder presies dieselfde toestande getoets en het 145kg Thrust @ 6500 rpm gekry.
May the Horisontal testing begin !! vhpy
Bullseye
Postby Bullseye » Wed May 26, 2010 7:42 am
Jaco
Jammer ek bly vra, maar wat het die enlin jou uitgewerk tot op hede??? Kyk sterk daarna.
