I would consider increasing the displacement of my VW. The rule of thumb on determining HP on a VW is to take displacement in cc eg 2400 and devide by 30. that will give you 80hp at 3000 Rpm. A 2.7litre should give you 90hp and shouldnt add to your weight. Only expensive bit is a stroker crank and it isnt even that expensive.T4flyer wrote:Guys this is driving me crazy, accepting that I can't afford a 912s, if you were spending my money, not yours, which would you choose Jab 2200 or 3300 and why?
Raven + Jabiru 2200 or 3300?
Re: Raven + Jabiru 2200 or 3300?
Would you mind telling us where you find such a crank? I am looking for a 78mm type 4 crank...krjockey wrote:Only expensive bit is a stroker crank and it isnt even that expensive.
- Signed up at flight school
Hi T4flyer
I am also building a Carl Babst Raven but have yet to decide on an engine.
There is a Zodiac xl in Secunda fitted with a Jabiru 2200 but I am not sure if it has flown yet. Saw it 2 months ago taxing up and down the runway preparing for first takeoff. Will try and get the contact details of the person.
Jo
Jo
Hi Justin,justin.schoeman wrote:Would you mind telling us where you find such a crank? I am looking for a 78mm type 4 crank...krjockey wrote:Only expensive bit is a stroker crank and it isnt even that expensive.
Have a look here
http://www.aircooledtechnology.com/stor ... hp?cat=269
Also Here
http://www.scatcrankshafts.com/
Kind Regards,
Gunter Rostek
Justin, if you have to, chase the wife out on prostitution, and moer the piggybank stukkend ek se, but if the choise was mine between the Jab and the VW, I would go for the Jab. It should make a good combination. I do not like VW. But then it is only me.
Its not only in the way you build a VW that counts, but also the sum of its parts.
It is much cheaper to build a type 1 as parts are readily available and reasonably cheap (don't by parts because there are cheap, because a lot are "performance parts" designed for the "hot them up" car guys and are of dubious quality)
I prefer the Type 4 as it is an inhently stronger engine and does not suffer so much from cooling problems (quite simply put, it was designed to lug a bus all day in very hot conditions)
Type 4 parts are scarce and good parts cost a fortune (ask me I have spent an arm and a leg on parts alone) Type 4 103 or 105mm cast barrels weigh 6.4kgs (for your 2,400cc) A good set of billet aluminium "Nikkies" (save 4kgs and improves cooling and reliability) will cost +- US$2,000. A billet crank +- US$1,600-1,800 and thats just the start. a really well built and reliable 2,600-2700cc type 4 engine will cost up to +-US$10,000 by the time its ready to fly.
If you keep a type 4's cc and Hp at a conservative 2200-2400 and +-80hp (at sea level) then concentrate on building a quality engine they can be relativity cheap & reliable. However, when you start pushing the power up the cost of maintaining a reliable set up goes up exponencially. Bring a bottle of wiskey and I will show you my parts invoices!
I don't quite agree with Boet, because if built correctly VW engines "can" be good engines. where I do agree with Boet is that given the choice I think the Jabiru is the one for me.
Looking more like the 3300 for my Raven, as I can't find any information on any flying Zodiac 601,s or Raven's flying on the 2200 Jab
Cheers T4Flyer
Cheers T4Flyer
