***Brand Spanking New Magni M22 on its way to SA***
Eagle
Postby Eagle » Tue Jul 15, 2008 2:45 pm
Hi Guys,
I have a Brand Spanking New Magni M22 - the Voyager of the Skies available for a very proud owner
to be. Here are all the Specifications & Details:
** TECHNICAL SPECIFICATIONS: **
WEIGHT
Empty weight (914) 272 Kg (600 lb.)
Maximum take-off gross wt - USA 550 Kg (1212 lb.) (Note: European "ultralight" limitations are 450 Kg)
Useful Load - USA 277 Kg (612 lb.)
PERFORMANCE
Maximum speed 125 mph
Cruising speed 90 mph
Absolute ceiling 4000 m (13,000 ft)
Service ceiling 3500 m (11,400 ft)
Take-off roll 70 m (230 ft)
Landing roll from 0 to 30 m (0 to 100 ft)
Rate of climb 5 m/s (950 ft/min)
Fuel tank capacity 72 lt (19 gal)
Endurance 3.4 h
Range (no reserve) 300 miles
DIMENSIONS
Rotor diameter 8535 mm (28 ft)
Propeller diameter 1700 mm (67 inch)
Overall width 1800 mm (71 inch)
Overall lenght 4655 mm (184 inch)
Overall height 2600 mm (103 inch)
DESCRIPTION
Airframe: Chrome-alloy aeronautical 4130 steel, tig welded. Fiberglass fuselage canopy. Fiberglass wheel pants. Fiberglass instrument panel.
Seat: With integral fuel-tank manufactured in epoxy resin reinforced with fiberglass.
Baggage Capacity: 150 Liters
Instruments: Rotor Tach, Altimeter, Airspeed Indicator, Flydat or EIS engine monitor
Engine: 914 Rotax Turbo, 4 cylinders, 4-stroke, water-cooled, 115 hp with electric starter and mechanical prerotator.
Propeller: Arplast 67 inch three-blade carbon fiber with ground adjustable pitch.
Rotor: two-blade, composite materials.
Controls: Single - Front Seat.
Trim Electric
STANDARD EQUIPMENT
Electric Starter
Airpeed Indicator
Altimeter
Flydat or EIS Instrument Monitor
Cockpit partial enclosure
Prerotator
Rotor Brake
Carburetor Heat and Temperature Gauge - 912 (non-turbo) only
Wheel Brakes and Wheel Pants
Landing Light
Electric Trim - Front
19 gallon Fuel Tank
Arplast Propeller
Magni Rotor
OPTIONS:
Electric trim control - rear seat
Removable Rear Seat Windscreen
Price for this Magnificent Flying Machine : R715 000 excl vat
Magni M22 Voyager_2.JPG (38.45 KiB) Viewed 1101 times
Magni M22 Voyager_1.JPG (37.49 KiB) Viewed 1102 times
Magni M22 Voyager_3.JPG (35.16 KiB) Viewed 1100 times
Nic Prinsloo
Managing Member
Eagle Aviation
Where Flying is a Passion......
Branch Contact Info:
Mobile: 076 970 2758
Skype: nicprinsloo
Email: Eagle@connect.co.za
