SOLD***New Shape Magni M16 Gyro @ Half Price !!! ***SOLD
Eagle
Postby Eagle » Tue Mar 25, 2008 2:59 pm
Hi Guys,
If you ever wanted a Gyro that is in a superb condition at a very good price here is the opportunity you have been waiting for !!!
***Specifications***
**Magni M16**
WEIGHT
Empty weight (914) 270 Kg
Maximum take-off gross wt 550 Kg.
(Note: European "ultralight" limitations are 450 Kg)
Useful Load - USA 280 Kg
PERFORMANCE
Maximum speed 125 mph
Cruising speed 110 mph
Absolute ceiling tested to 16,500 ft in S.A.
Take-off roll 70 m
Landing roll from 0 to 30 m
Rate of climb 5 m/s (1000 ft/min)
Fuel tank capacity (72 ltr)
Endurance 4 h
Range (no reserve) 550 Km.
The aircraft is complete with the following instruments:
a. Flydat instrument monitor
b. Rotor RPM
c. Altimeter
d. Vertical Speed Indicator
e. Fuel Gauge
f. Manifold Pressure Gauge
g. Airspeed Indicator
h. Icom A 22 Radio
i. Intercom
*The rotor blades and propeller has been balanced.
*The aircraft also has a complete set of lightweight x-country covers.
*The aircraft was completely rebuilt with the wide cockpit.
*The engine has done approx 550 hrs.
*There is a spare instrument panel available if an Enigma or something similar is to be fitted. It will also help to relocate the instruments if a tall person buys the aircraft and wants to move the panel higher.
*The annual inspection and change of ownership will be facilitated by the owner.
*There is also a custom built trailer available should the buyer be interested for approx R 20 000.00
***The Total Package : R375 000-00 !***
If you are interested phone Nic @ 0824900577
Magni M16.jpg (76.58 KiB) Viewed 1923 times
Nic Prinsloo
Managing Member
Eagle Aviation
Where Flying is a Passion......
Branch Contact Info:
Mobile: 076 970 2758
Skype: nicprinsloo
Email: Eagle@connect.co.za
Eagle
Postby Eagle » Thu Apr 03, 2008 1:41 pm
Sorry Guys but Mr Braam le Roux is the proud new owner of this Magni M16.
Congratulations Braam and may you have many pleasures and accident free flying with ZU-BUR !
Nic Prinsloo
Managing Member
Eagle Aviation
Skype: nicprinsloo
