Xenon
Induna
Re: Xenon RST build new pics 30 June
Postby Induna » Wed Jul 06, 2016 3:11 pm
greg vos wrote:
Thanks Jacques
Hows it going down Kazak?
Greg, it is cooking in Kazakh!! It is extremely hot and the humidity is horribly uncomfortable!
I cannot wait to be back in the country in two weeks, as I want to fly the little red machine.. She is just a lot of fun!!
J
ZU-RHT | Magni M18 Spartan
Vertical Tango
Postby Vertical Tango » Wed Jul 06, 2016 3:36 pm
greg vos wrote:
Vertical Tango wrote:I do not have a detailed photo in my lib. This one is not great either but it will give you an idea of at least the horizontal part. Then it slants towards the rear at 30 deg right down to the existing fiberglass floor. Obviously it does not have a square cut to be able to snug the round belly.
VT have you put an aluminum floor pan in :?: I really like the heel plates.
I'll take some pics this week-end as it is better than my explanations.
greg vos
Postby greg vos » Wed Jul 06, 2016 8:48 pm
PPL (A)
PPL (H)
CFI Gyro & Test Pilot
Vertical Tango
Postby Vertical Tango » Wed Jul 06, 2016 10:17 pm
Greg, all these figures are to satisfy the paper pushers who pretend overlooking at your well being, because it has been decided that you are not capable of looking after yourself. I remember in the recent past, the powers tried to impose an AP to change even a spark plug because even if you built your own machine, you cannot have the knowledge to do such complicated task.
My approach is quite simple. It is my backside that I am looking after. I often look for advice when I don't know. The final decision is mine. If I feel that my teeter bolt is still good at 1000 hours and the bushes have no play, I'll still fly with those. And no one can prove if I changed anything or not, so what is the point ? In all cases, if I have an accident and I followed all the rules, big brother won't take anyway any responsibility.
So factory recommendations are only recommendations and should be adjusted for each specific aircraft. Logic must prevail specially if advice comes from God Celliers.
I have done my own check list, quite extensive I must say, and it applies only to my machine. My AP thinks along the same lines and logic. We go thoroughly through it every year and it works like a charm.
gyropilot
Postby gyropilot » Thu Jul 07, 2016 7:35 am
like the pedals - bought or machined?
FAFK - ZUDMJ
Vertical Tango
Postby Vertical Tango » Thu Jul 07, 2016 11:20 am
gyropilot wrote: like the pedals - bought or machined?
Machined. They rotate on the control shaft to follow the position of the shoe sole and return centered under light spring tension.
gyropilot
Postby gyropilot » Thu Jul 07, 2016 11:49 am
nice !!!! - CNC machined or hand?
FAFK - ZUDMJ
greg vos
Postby greg vos » Fri Jul 08, 2016 11:40 am
PPL (A)
PPL (H)
greg vos
Postby greg vos » Tue Jul 12, 2016 9:37 pm
PPL (A)
PPL (H)
FO Gyro
Re: Xenon RST new pics 12 July - new drama
Postby FO Gyro » Tue Jul 12, 2016 10:04 pm
Thanks for the updates. Sorry to hear about the cracks.
Glenn Poley
Moderator
ex ZU-AWE Windlass Trike
ex ZU-AOA VPM M16 Gyro
ex ZU-BPU Sycamore Gyro
ex ZU-GJP MT-03 Gyro
ex ZU-NPC RV9A
ZU-RJR Magni M24 Orion Gyro
Vertical Tango
Postby Vertical Tango » Tue Jul 12, 2016 10:23 pm
Hi Greg,
Understand your concern about the mast. I believe you are not the first one to have a damaged mast bracket, and in your case it is the mast itself. Could you please send a pic from a bit further back of the same hole to understand where it is in the machine. You speak about removal of covers to inspect it. I don't understand where you have a cover here as I can see all my mast bolts.
The prerotation cycle I believe is also a problem when some pilots have the phobia of racing and timing how long it takes to rev the rotors to roll start. That mast will twist if the friction is not controlled correctly and the attachments are the first things that go. My attachment is different than the factory one as I have put nylon blocks to bring the cabin closer to the mast instead of having the bolt at the extreme end of the bracket.
Thanks for putting us aware of any weakness you find.
greg vos
Postby greg vos » Tue Jul 12, 2016 10:46 pm
PPL (A)
PPL (H)
greg vos
Postby greg vos » Wed Jul 13, 2016 1:25 pm
PPL (A)
PPL (H)
gyropilot
Postby gyropilot » Wed Jul 13, 2016 2:33 pm
Yep this machine has less than 200 hours and we see cracked mast attachment points :shock: :shock: so boys and girls who own and fly Xenon with this old aluminum mast I suggest in the line of flight safety you all go and tear down your machines and have good look, because this cannot be seen in the standard pre flight.
GEESUS and to think we / I've been flying it like that! :shock: IMO what we have here is the first hole in the swiss cheese - bad workmanship (un checked / torqued mounting bolt) the crack propagates right through the hole! so what will it take now to rip the mast off? hard landing or hard turn?
FAFK - ZUDMJ
greg vos
Postby greg vos » Wed Jul 13, 2016 2:53 pm
PPL (A)
PPL (H)
