Mountain flying
Low Level
Re: Mountain flying
Postby Low Level » Thu Apr 09, 2009 9:07 am
FO Gyro wrote:Turbulence at altitudes below 2000 doesn't phase me at all, but not when so high!
Why is it ?
Coming back from the cosmos fields on Saturday I climbed to 2 500 ' AGL, fighting my demons all the way. The slightest bump, or shake and I felt like I'm falling from the sky. 500 ' I will throw the gyro around without a fear in the world.
My stomach turns just imagining those heights when looking at your pix. :shock:
ZU-CFW
old no 7
Re: Mountain flying
Postby old no 7 » Thu Apr 09, 2009 2:08 pm
Absolutely bootiful pics Glenn,
I'm sure you're not missing Gansta's Paradise for a second.
Would you mind "loaning" me a few hi-res copies I've just got to have a few of these inspirational posters on my office walls. (-)
the other Glen
ZU-f-ALL
FO Gyro
Re: Mountain flying
Postby FO Gyro » Thu Apr 09, 2009 2:52 pm
Low level, I feel the same as you. It seems silly really.
Maybe it's made worst because one minute we are flying at 200 feet maybe, and then next minute at 2500 feet. The sudden change in height feels like one is in outer space, since you are twelve times higher.
I do feel as though I have got better though with time, although I'm still not totally over it yet. My wife has studied Psychology and she says one needs to de-sensitive oneself from the fear.
If for example you feel totally ok up to say 1500ft. Try flying at that height for a while. Then do some gentle manoeuvres, the same manouevres you would be comfortable with at a lower level eg. steep turns, flying at a slower speed and yawing the gyro around. This might psychologically tell your brain that just because the gyro is higher, you won't fall out, and that it is ok. Then try flying slightly higher, say 500 feet higher, and then trying the same thing, only when you feel comfortable with the height. The aim is to "practise" flying as high as possible, whilst still feeling comfortable.
Doing this might help so that one day, when you are at a very high altitude, and you do encounter turbulence, you won't get a tight stomach, and your brain will tell you that you will be ok, without the fear factor.
Try this, see if it helps. In theory it should. When I was up there at 6500', I did a steep turn, and I think it might have helped a bit. The trick is to "practise" some high flying now and again to keep oneself de-sensitised.
There is also that self-hypnosis that you can try, when falling asleep at night, that will train your subconscious to also believe that you don't have to fear heights.
Good luck. Hope it helps. vhpy
Glenn Poley
Moderator
ex ZU-AWE Windlass Trike
ex ZU-AOA VPM M16 Gyro
ex ZU-BPU Sycamore Gyro
ex ZU-GJP MT-03 Gyro
ex ZU-NPC RV9A
ZU-RJR Magni M24 Orion Gyro
Re: Mountain flying
Postby Gyronaut » Sun Apr 12, 2009 7:32 pm
FO Gyro wrote: one minute we are flying at 200 feet maybe, and then next minute at 2500 feet
Glenn, I watched you take of with Johan Meyer and his mate at FAFK the other day and man oh man, you were BALLISTIC! That MT03 climbs like a homesick angel! I think you were at 2500 ft when you crossed 14! :lol:
Looked awesome by the way!
Len
FO Gyro
Re: Mountain flying
Postby FO Gyro » Sun Apr 12, 2009 8:14 pm
Thanks Len. She performs very well, especially with 1 up!
It was one of those days that even though the wind wasn't blowing much, when I landed there earlier, it was almost a zero groundspeed landing. It was almost as though the air felt "heavy", and the gyro had so much lift. Maybe the low temp created a lower density altitude, which increased the performance.
Glenn Poley
Moderator
ex ZU-NPC RV9A
