New Airfield in Hartbeespoort
MPL Pilot
Postby MPL Pilot » Wed Oct 05, 2011 9:06 pm
I would like to get some comments from gyro pilots asto what they would like in an airfield.
What we can offer is basicly a 36/18 close to Zilkaatsnek on a plot, south of the Magaliesberg.
36 would be taking of uphill, most of the time a wind from the north thru Zilkaatsnek, helping with takeoff.
18, downhill, with the advantage of gaining groundspeed due to gravity.
Coordinates: 25°43'9.83"S
27°55'0.05"E
Runway lenth, 600m minimum and 1km max, depending on the layout.
The Google map give an indication of the setting, to the north a squaters camp and to the south
open field.
For trikes and LSA fixed wings (Bantams and Beavers) it would be easy.
Your thoughts would be appreciated.
If this runway is safe, it could be an amazing flyin for many pilots as Dozi has some things
up his sleeve for the future.
Follow the dots on the image, that would be max lenth.
White dots would indicate the ideal runway
If you fail.... get up and try again. That is the only way to succeed!
ZS-VMS, ZU-RGG, ZU-FWY
MPL Pilot
Re: New Airfield in Hartbeespoort
Postby MPL Pilot » Mon Oct 10, 2011 8:25 pm
Thank you for the thoughts on the airfield to those that contacted me.
It has been confirmed, soon this grass runway will be a reallity.
We have interest from ppl pilots as well, the lenth of the runway
will be 1000m.
Veilig vlieg
Runway 36 18.JPG (35.71 KiB) Viewed 14417 times
pietmeyer
Postby pietmeyer » Mon Oct 24, 2011 6:18 am
It will be good to have more places to fly to. Please let us know of the progress. Also place it then under Hangar Talk so that all us trike pilots also can be informed or is this for Gyro's only (**)
Piet Meyer
Jabi J400 ZU-DUU (Wonderboom)
MPL Pilot
Postby MPL Pilot » Mon Oct 24, 2011 12:46 pm
pietmeyer wrote:.... or is this for Gyro's only
No, definitely not, any aircraft that is able to take off safely
on a 1km runway is welcome.
Hangers will take some time, but we will get there.
pietmeyer
Postby pietmeyer » Tue Oct 25, 2011 4:07 am
When is the intended opening of the runway? What plans do you have? Looking forward to flying there
Piet Meyer
MPL Pilot
Postby MPL Pilot » Thu Oct 27, 2011 7:47 pm
Hi oom Piet
We have not set a date for opening yet, will get going in November, mowing the grass and
removing trees to get at least 500m available. The rest will be a week to week operation.
We would like it to be a pilot friendly runway, summer and winter, that means it will not be a quick- quick,
but when it is done, all that use it will benefit from the landing strip.
We will have an inauguration, the date will be announced in due time, Dozi
will have to get his singing buds together for the event. (^^) (^^)
Fly safe
MPL Pilot
Postby MPL Pilot » Sun Nov 20, 2011 7:35 pm
pietmeyer wrote:Also place it then under Hangar Talk so that all us trike pilots also can be informed
I will do as soon as the runway is ready for use.
We had the trees removed a week ago, which left a lot of holes and roots from the trees.
Total useable runway lenth is 850m and 30m wide.
The grader finnished today, leaving a smooth surface. I would strongly suggest no aircraft should land on this runway at this stage, since the tree holes has been closed up but the soil needs to be compacted in those areas. We will do the compacting asap.
All we need now is some rain, and the grass to grow again, with the grass roots visible
it should not take too long.
Until the runway is covered with gras, it is advisible not to land here shortly after rain, unless you fly a 4X4 ##
Thank you to all the pilots that flew over the runway in the passed weeks, it kept us motivated to get going and keep going.
Grader 19112011.jpg (25.03 KiB) Viewed 13989 times
Bulletjie
Postby Bulletjie » Wed Jan 11, 2012 4:26 pm
What is the progress on this runway? Can't wait to come and visit!
MPL Pilot
Postby MPL Pilot » Sun Jan 15, 2012 2:32 pm
Gerhard Burger wrote:What is the progress on this runway? Can't wait to come and visit!
Hopefully the runway will be finnished by the end of Feb.
The northern part of the runway is usable, there are 2 white lines crossing the runway at the southern side to give an indication of useable
runway, from the two lines to the end of the runway at the northern side is 550 m.
We have removed trees and the holes was filled, the ground just gave way a bit as we drove over it to compact and will be refilled soon.
I landed there yesterday and was surprised how smooth the northern part of the runway was, to what I am used to.
You are welcome to land here if it is sufficiant for take off.
Just give me a ring on zero 7 9 516 85 zero 4, i will meet you there.
I will get a windsock during the week, but there is a couple of flags indicating wind direction.
Fly safe!
milegrin
Heard about flying
Postby milegrin » Sun Feb 07, 2021 7:21 pm
If I browse to those coordinates via google maps, it shows a squatter camp a shape of what could have once been a runway. If it is so, it is sad to see. :(
https://www.google.com/maps/place/25°43 ... 14642,17z/
lion
Postby lion » Sun Feb 07, 2021 11:27 pm
Wow, it would be interesting to hear what happened there. Was it private land that was occupied? Whoever created the runway must have invested some good money there.
