Airfield Weather Stations
Sonex711
Postby Sonex711 » Wed Sep 07, 2005 3:33 pm
Quite a few airfields have weather stations that you can access via cell phone. How about everyone post the details here...
Crosswinds (Tarlton) - Call 084 450 9944 for current wind and temperature.
Smiley
Postby Smiley » Thu Sep 08, 2005 12:56 pm
Hello guys
What will it cost to purchase and do the setup on a system like this?
ZS-WGT
Springs 122.40
DarkHelmet
Postby DarkHelmet » Thu Sep 08, 2005 1:09 pm
http://www.realti.co.za to see how to use it. Cost R5 per SMS
Circus Circus Airfield MLCI
Lanseria Lanseria Airport FALA
Microland Microland Airfield MICR
Rhino Rhino Park Airfield rhinop
Rhodes Rhodes Mountain PEND
Rhodes Rhodes Mountain rhodes
The Cat Club Bronkhorstspruit Dam CATC
Tzaneen Tzaneen Airport FATZ
Smiley
Postby Smiley » Thu Sep 08, 2005 1:35 pm
Darkhelmet
I don't seem to get any weather info, just phone no's and runway info?
Surface winds + direction??
ZS-WGT
Springs 122.40
DarkHelmet
Postby DarkHelmet » Thu Sep 08, 2005 2:40 pm
You send an SMS to the number on the site with the station code of your choice - it SMS' you back?
Smiley
Postby Smiley » Thu Sep 08, 2005 2:51 pm
I did, to 36969.
The info coming back only has airfield info, no weather info [0* -0<
ZS-WGT
Springs 122.40
Griffin
Postby Griffin » Thu Sep 08, 2005 5:38 pm
Contacted C.W. Price [cwp@cwprice.co.za] re the weather station
From his e-mail
1 X W-608/0 Weather Word Metric R3 200-00
1 X 7911 Anemometer Assy R1 250-00
Options
1 X 7852 Raingauge 0.2mm R 750-00
1 X 7859 External Temperature/humidity sensor R1 300-00
Price excludes VAT and Postage.
All items Ex Stock at present (Raingauge ± 10 days)
Please note that if Weatherword connected to the telephone landline adequate lightning protection must be provided.
Weatherwork also requires a 12 vdc (500mA or less) power supply.
The anemometer uses a reed switch, 26.6 pulses/min/mph with direction being a 0-20 k ohm pot.
This system would be connected to a landline or a GSM (cellphone) device. (additional cost)
My only concern is the reed relay used to measure the wind speed and to a lessor extent, the pot (variable resistor) used to determine direction. Both devices have a limited life. I would have been happier with an optical sensor for both speed and direction
ndiza
Found a flight school
Postby ndiza » Fri Mar 24, 2006 10:39 am
Hi Smiley,
To get weather data from Lanseria, send FALA W to 36969.
Sending FALA to 36969 will merely give you general airfield info.
Other examples of available categories:
FALA C will give you co-ordinates & radio frequency at Lanseria
RHINOP A will give you amenities at Rhino Park
FALA R will give you additional runway info at Lanseria.
MICROL H will give you hazard info from Microland.
The niftiest function is Balito nearest, which will send you the codes of the 4 nearest airfields to Bailto airstrip.
Check out our website www.realti.co.za for more info, including how to get the correct code...
We can supply fully autonomous weather stations on a rental or sale basis to any club that would like to have real time weather available from their airfield. Simply call me 082 600 5881 (Note: we are trailering our trikes through Namibia, Zambia, Tanzania, Malawi & Mozambique from mid-April to end-June, so I will only be able to install before or after then).
Thank you
Stephen (ZU-BTR)
www.realti.co.za
Mobile +27 82 600 5881
ndiza
Postby ndiza » Fri Mar 24, 2006 10:41 am
Cost is R5 per interrogation (billed to your account by your service provider).
Stephen (ZU-BTR)
www.realti.co.za
