Ryme for preflight checks and pre-takeoff checks
Postby Tailspin » Wed Jul 29, 2009 8:18 am
Hi All
What is the Rymes that you guys use for all your checks -PreFlight and Pre-Takeoff.
I am having a hard time keeping all this in my nut so i am looking for a ryme or something to help me remember.
A NEARLY converted Tailspin.
Wargames
Re: Ryme for preflight checks and pre-takeoff checks
Postby Wargames » Wed Jul 29, 2009 8:35 am
To Many Pilots Fly In Heaven Too Early
T - Trottle check
M - Master & Mags
P - Prop & Pitch
F - Freedom of controls, Fuel (level, cap, pump)
I - Instuments
H - Harness, hatches, hydrolics & Safety pins
T - Temperature
E - Engine
This is just a quick write down. Add own checks in there as necesary.
Postby Tailspin » Wed Jul 29, 2009 8:55 am
Thanks Wargames.
This is why i Love this Forum !!!!
Dish
Postby Dish » Wed Jul 29, 2009 9:05 am
OhhhhhhhhhHHHHhhh - Is THAT why you love the forum..... we all thought it was because of the people... :? :?
RV9
DISH
Postby Tailspin » Wed Jul 29, 2009 9:29 am
Dish wrote:OhhhhhhhhhHHHHhhh - Is THAT why you love the forum..... we all thought it was because of the people... :? :?
Hey Dish
Yea luv you too boet xxx
Just don't tell my wife she is already starting to think i love my Aviation buddies more then i Love my Mother-in-Law :twisted:
It is the People that make the Forum so good. !!!!
Dish
Postby Dish » Wed Jul 29, 2009 9:33 am
YEEAHHHHH - defnitely the people.... vhpy vhpy vhpy
when are you finishing your conversion ??
RV9
DISH
Postby Tailspin » Wed Jul 29, 2009 10:12 am
Dish wrote:YEEAHHHHH - defnitely the people.... vhpy vhpy vhpy
As soon as i can get Flying again.
Just had my Flying time for this week cancelled. :(
Need to get 3Axis converted before I can convert onto the SunBird. I have a few instructors waiting for the sunbird to Fly then they will convert me directly.
So working my ass off to get her finished.
Postby RV4ker (RIP) » Wed Jul 29, 2009 12:10 pm
Same as above....
Too Many Pilots Go Fly In Heaven Early.
T - Test controls (full free play movement and visually verify they move in the right direction) Trim set for take off, Temp (& pressure) in green, Throttle friction nut set (tight)
M - Master on, mags on both, Mixture (leaned for alt in my case) full
P - Pitot cover off, primer locked, pitch set (full) and pressure in green
G - Gyro's (Suction on vac pump) and set AH & DI (although I usually reset this once lined up on runway to runway direction)
F - Fuel (sufficient & in balance), select fullest tank (don't change from tank you did runup on) and flaps (nil for RV, first stage for most others)
I - Instruments top to bottom left to right (set qnh and make note and check all reading as they should)
H - Hatches, latches and harnesses (almal vas) - Lock doors and ensure pax and luggage secure
E - engine (check temps and prssures again and make sure all circuit breakers are in.
then GOOI KOoLE....
Postby Morph » Wed Jul 29, 2009 4:05 pm
My prestart checks
FART :wink: 8)
Fuel on , Flaps normal
Avionics on, Altimiter set
Radio on, fRequency set,
Throttle full off, friction nut tight
Pretakeoff
FARSERT
Fuel taps open both, Flaps normal, freedom of control movement
Radio on, fRequency set, Signal check
Secure - seatbelts, doors, cubby
Engine - oil pressure, oil temp, water temp
Runup - mag check, radio call
Takeoff
These are mine, in my plane they make more sense than the traditional ones
KFA
Postby KFA » Wed Jul 29, 2009 10:43 pm
Too many Pilots Forget Good Habbits Incredibly Easily
my checks are identical to RV4ker except I add the landing lights on at the end. I also do these checks after my runup and mag checks. The reason being that I toggled some switches during mag checks and this rhyme is to make sure they are all in the right places again.
After take off is
Brakes Undercarriage Throttle Ptch Mixture Fuel Flaps Electric and on downwind the same except the it's mixture pitch throttle and radio call
KFA
Postby KFA » Wed Jul 29, 2009 10:48 pm
On X country it's FREDA every 10 min or so
F Fuel- quantity, tank selection etc.
R Radio call
E Engine - Scan instruments, mixture etc.
D Set Direction indicator and check Compass heading according to flight plan and nav etc
A Altitude
Postby Tailspin » Fri Jul 31, 2009 11:13 am
Thanks All
I will extract everything i can and see what works for me.
Thanks KFA I know the freda etc it is more the pre- startup etc checks, There confusion reigns sometimes although i do get through them.
Brain is getting rusty sucking all that Nitrate and butrate with Ali paste. (**) (**)
Jimbo
Postby Jimbo » Mon Aug 10, 2009 6:01 pm
Cadburys Dairy Milk Very Tasty..
Compass
+- Deviation
=Magnetic
+- Variation
=True
I think I learned that in school geography or somewhere. I'm not an aviator so it can't be from aviation!
BOATCH
Postby BOATCH » Tue Aug 11, 2009 3:31 pm
CPWI
C= CLIPS CAPS COMUNICATION CONTENT
P= PANNIERS POWER PASSENGER
W= WINGS WHEELS WINDSOCK
I = INSTRUMENTS.
KFA
Postby KFA » Tue Aug 11, 2009 7:12 pm
For Trikes I use
Rings-Check Rings - 7-9
Wing- Free Movement, Zips, Bungees, Battens, Hangpoint
Undercarriage-Start Front, Set Instruments, Radio Freq, Intercom, Mags Both on, Choke and cruise throttle off, Panniers closed,Carbs no fuel leaking, Fuel Cap closed. Exhaust not loose
