Side Slip
Re: Side Slip
Only the Operators Manual will tell you that... Some aircraft have no restrictions on slipping with flap, some do have restrictions.
Re: Side Slip
Check POH, else
Hang it on the prop with full flaps (near the stall and not comfortable)
Slip it in with no flaps. (Practise at alt. i can get the RV to loose 2000ft a min at 80mph and when "kicked out" she just squats without much
(still practising) a bump
Also consider a descending turn approach to finals maybe not coming directly over the obstacles...
There are some awesome sites on the web. Google stick & rudder or back country flying or bush flying. Some of the sites in Canada are awesome for this sort of thing. We hardly have any strips they would consider "short"
Re: Side Slip
What airframe Boatch?
As mentioned, some manufacturers do not recommend side or more correctly for your case, forward slips with flap. This is due to "blanking" of the tailplane and causes a nose down bunt which is easily recoverable at altitude but not so good when you are ducking in over the trees!
If your plane is approved for slips you should practice and use this useful descent aid.
http://www.youtube.com/watch?v=cy6pzI9c ... re=channel
I use slips all the time, with lots of flap.
To me there is nothing more satisfying than a full rudder slip right into the flare, finishing it with a 3 point touch down.
Nottaquitta
- Stephan van Tonder
Re: Side Slip
We use slip with first notch of flap on the cheetah often - yours being a skyranger it should be Ok as it's a similar airframe.
Re: Side Slip
- BOATCH
Re: Side Slip
Thank for all the inf on the side slip,i read the manual and as Stephan said they do recomend one to use sideslip on obsticals. But i must say the clips of the pilot using the slip does it very neat.I will go out and practice it this weekend.Did it in training but that was some 250 hours back and always using 1.4km of runway one seem to not use it mutch.
Re: Side Slip
Now that's what I'm talking about!RV4ker wrote:http://www.youtube.com/watch?v=wW8GRJI6Kz4
Nottaquitta
Re: Side Slip
Just remember to never introduce up elevator while holding the controls crossed for side slip as that are all the elements for a snap roll and keep the speed well above stall.
- BOATCH
Re: Side Slip
Stephan thanks that is something to keep in mind.I used the side slip this weekend and my wifes eyes got as big as golf balls.She have flown with me in the past and did not know wat sideslip was,but i get a nasty vibration on the aircraft on a S\S to the right side but not to the left.
Re: Side Slip
This statement cannot go unchallengedStephan van Tonder wrote:Just remember to never introduce up elevator while holding the controls crossed for side slip as that are all the elements for a snap roll and keep the speed well above stall.
Snap rolling a Bushbaby or similar
Slip The wings are banked with ailerons and the turn stopped with rudder opposite to the direction of the turn.
SkidThe wings banked with aileron and too much rudder is used in the direction of the turn.
In an uncoordinated stall, the wing which stalls first will be the slower one and the one towards which the rudder is turned.
Both maneuvers are uncoordinated.
Of the two, the skid is far more dangerous than the slip as it will be the lower wing which will stall and can rapidly invert the aircraft.
A stall during a slipping maneuver will have the high wing stall first, allowing a lot more time to identify and correct the condition.
Bottom line, know the difference between the two. Provided your aircraft is rated for them, practice and use slips. Beware of skidding turns, these can bite you in the ass very quickly if you are slow and pull the nose up.
Nottaquitta
Re: Side Slip
Some aircraft to roll VERY agressively in a cross controlled power on stall (i.e. what you would get when stalling in a slip). A Jabiru is a good example - it will be inverted before you can blink.
Other aircraft (like apparently the Cessna Skycatcher!) can end up in an unrecoverable spin from a cross controlled stall.
Others just nod down gently, and you keep on flying.
Re: Side Slip
I am trying to clear things up.
Lots of ambiguity for the newbies! this is the training board so let's get it right.
We are talking about slips, there is no power in a side slip used to increase the rate of descent.
A snap roll is a high speed stall maneuver.
It is pertinent to point out the difference between a slip and a skid.
Nottaquitta
- BOATCH
Re: Side Slip
Mogas ,i think you got it right with the no power on the slip,cause that is what i did wrong,TO MUTCH POWER.
Re: Side Slip
Mogas wrote:I am trying to clear things up.
(There are times you use power-on slips - mainly for visibility, but that is indeed a different beast.)
