Exhaust
Exhaust
Hi guys,
I need to make mods to my exhaust system. Baffle and branches. Can anyone suggest a company in Jhb? Is there someone who actually goes out to site and takes the measurements etc?
Re: Exhaust
Why don't you chat to Philip from Bundu Aviation. He did very good mods on his 801 & has the experience. If you want contact details let me know.
Re: Exhaust
Thanks Mike ill tyalk to him.
Re: Exhaust
If you need some extra piping (that looks like a profile tube) let me know.
Re: Exhaust
Oh k@k here we go again...
Is you piping (that looks like a profile tube) heat resistant or is it just full of HOT AIR
Re: Exhaust
Is this for a 4 or 2 stroke. I wouldn't suggest messing around with two stroke exhausts
On my 912 I took the whole engine, engine mount and all, to Cowley Exhausts in CT. This way they could do a really neat installation. The 912 exhaust ships with a few lengths of tubing, two dounuts for the bends and the SIlencer
Re: Exhaust
4 Stroke. Prblem is Morph engine is already installed with electrics.
Re: Exhaust
I understand,
The next option is put it on a trailor without wings and take it in to them. It is all Stainless steel so you really need someone with the right welders to do the job properly
It is absolutely worth it getting it done professionally
Re: Exhaust
enige probleme met exhaust vir herstel werk of oormaak , Kan 2stroke reg maak maar nie oorbou nie , 4 stroke kan ek oor bou van nuuts af,het net die afmeetings nodig.
- Blue Angel
- Survived first engine out
Re: Exhaust
Marius daai is nie n profile tube nie, dis a tune pipe
- bobthebuilder
Re: Exhaust
Hi Massimo,
On the subject of Cowley, there are a few local companies that are making automotive exhausts.
You could try TNT exhausts in Germiston. They do custom exhausts, tube bending, welding etc.
The other people you could try is Wild Cat. They also do fabrication, and had a very neat and tidy workshop. (well ... the last time I was in there years ago)
Maybe give them a try.
My 2c
My 2c
Byron Kirkland
Re: Exhaust
TNT Exhausts in Germiston (Knights actually) are definately the ones to go and see if you are looking for a four stroke exhaust system on a 912. I know of one they fitted to a CTSW that pushed the power up to around the 120 hp range and it was alot quieter than the standard exhaust. The owner needed to take the aircraft there to have it fitted to make sure everything fitted inside the cowling.
I had an enhaust made by Jeremy Pinkus for a Rotax 462 engine. Pushed the power from 51 hp (at sea level) to around 75 hp at 5500 ft (Calculation was done by Piter De Necker as he had to make the new prop) The fuel consumption dropped drastically to. He also does 4 stroke exhaust systems and his work is that of a perfectionist.
Exhaust sytems make far better improvements on 2 strokes than on 4 strokes but the standard exhaust on the 912 and 914 engines are so restrictive due to European noise constraints.
There was a company called R&D Aerosport in the States that could get the power up to 125 hp just by changing the exhaust system on the 912 but the noise test would never pass. (Dont think our AP's would even notice).
- Duck Rogers
Re: Exhaust
Please continue this thread.......I still have a FULL bag of popcorn left
Re: Exhaust
Well please enlighten us Mr Rogers on how to get this done.Duck Rogers wrote:Please continue this thread.......I still have a FULL bag of popcorn left![]()
Re: Exhaust
Have you got contact detail?Chunky wrote: I had an enhaust made by Jeremy Pinkus .....
Massimo - Pls share the details with us if you find someone.
