582 Autolube disconnection
Spurwing
Postby Spurwing » Wed Jan 14, 2009 7:52 am
Hi Guys
The debate re pre mix or autolube continues.
Please can someone tell me how to disconnect my autolube system so I can start premixing.
spurwing
Re: 582 Autolube disconnection
Postby Boet » Wed Jan 14, 2009 10:24 pm
Stop listening to shitty advice and leave your autolube system connected. It is such a simple device that there is not much that can go wrong. You PAID for it. USE it. It is a very reliable system that will save you a lot of money in the long run. What kind of engine you got?
kloot piloot
Postby kloot piloot » Wed Jan 14, 2009 10:27 pm
vhpy vhpy "Don't scratch if it does not itch !" vhpy Quoted from somewhere off this forum.
Roel Jansen
ZU-IAR powered by BMW 1200
Big-D
Postby Big-D » Thu Jan 15, 2009 11:02 am
Spurwing - Let an AP/AMO do it for you - Did not cost me much at all to have the autolube removed by Pro
I am not saying it is the way to go, very much a personal thing
D
Big D
Postby Duck Rogers » Fri Jan 16, 2009 10:07 pm
Big D wrote:I am not saying it is the way to go, very much a personal thing
Personal thing indeed. Remove the damn thing...! vhpy
Wargames
Postby Wargames » Sat Jan 17, 2009 1:38 pm
Spurwing wrote:Hi Guys
Is there a problem that you want to disconect it??
Postby Boet » Sun Jan 25, 2009 7:59 pm
Hallo Ducs, wil jy nou he die ou moet ook sy errouplyn opdinges soos joune?? :wink: Los jou auto lube in broer, die ouens gee vir jou BAIE slegte raad. vhpy Ducs was lekker om julle gesigte te sien, blue skies en veilig vlieg, Ek is darem ook genadiglik veilig terug by my huis. vhpy vhpy
vliegvark
Postby vliegvark » Mon Jan 26, 2009 12:12 am
it's a simple oil pump that runs in oil failure is 3% mixing of oil failure is 20% in the USA ......and you use less oil tjis is a no brainer set it right and leave it .
you don't see a outboard or a bike without autolube I wonder why
Thatchman
Postby Thatchman » Mon Jan 26, 2009 3:59 pm
Granted there have not been many failures........but when it does fail, there is no warning light - you going down. I personally know two people that its happened to and one nealy died. :shock: :shock: :shock:
But hey......leave it on or take it off ($$) ($$) ($$) , there are more important issues rather concern yourself with. Winter is coming. If you disconnect it you can leave the bottle on and fill it with Old Brown Sherry for those cold away trips
IF IT STILL WORRIES YOU THEN BUY A 912
ZU - forePLaY
Postby Duck Rogers » Mon Jan 26, 2009 11:22 pm
Boet wrote:Hallo Ducs, wil jy nou he die ou moet ook sy errouplyn opdinges soos joune?? :wink: Los jou auto lube in broer, die ouens gee vir jou BAIE slegte raad. vhpy Ducs was lekker om julle gesigte te sien, blue skies en veilig vlieg, Ek is darem ook genadiglik veilig terug by my huis. vhpy vhpy
Lekker om jou te sien by die AP seminaar Boet. Genadiglik veilig terug by die huis? Was Kulula dan so sleg :shock:
Nee, ek en die autolube is nie maatjies nie. Dis verseker 'n persoonlike ding. As jy nog nooit k#kk@s met die ding gehad het nie stem ek saam...........los dit uit. Wanneer jy eers 'n stel afgetrap het met een wat opgepak het, sal jy weet hoekom ek dit nie laaik nie.
Postby Boet » Tue Jan 27, 2009 7:53 pm
Ducks, ek is k@k bang om in groot erries te vlieg, daar is te veel plekke wat n AP se wakende oog kan ontglip. :shock: My senigwees was behoorlik moertoe met die Trip Big smoke toe, want dit was nag. So donker soos die binnekant van n koei. Ek kon boggerall buite sien nie. Terugvlug Fairest toe was OK, want toe die seatbelt liggie doodgaan, het ek en JJ heel voor gaan sit, die wereld bekyk, en terug huis-toe ge-navigate. Lekker as jy heeltyd weet watter dorp le daar onder. Land die groot erries altyd so HARD?? :shock: :shock: Ek het amper gedink ons is afgeskiet. :wink: Nee, ek is nie bang nie, maar verkies liewer MY Turbi of n BB. Window seat ge-garuantee elke keer. (^^) (^^) (^^) (^^) (^^) (^^) (^^) (^^)
Blue skies!
Postby Morph » Wed Jan 28, 2009 9:07 am
Boet wrote:Land die groot erries altyd so HARD?? :shock: :shock: Ek het amper gedink ons is afgeskiet. :wink:
Boet, were they premixing or not? Could have an effect :wink: :lol: 8)
Low Level
Postby Low Level » Wed Jan 28, 2009 10:51 am
Morph wrote:Boet, were they premixing or not? Could have an effect
Seker Boet het self gemix - anners is daar te veel Coke, en te min ys. :wink:
ZU-CFW
tandemtod1
Postby tandemtod1 » Thu Jan 29, 2009 6:18 pm
When you are approaching the runway on a steep final, you will have high revs and low throttle setting. On premix, this equates to low oil injestion causing very high wear rates on the engine. On a long final, it may mean engine seizure. On an autolube system, providing the engine is turning, it's getting oil. It's a no brainer. Leave the autolube system in.
But what about a 503 I hear you all ask? The 503 uses heavy duty type chain saw oil which is formulated for extreme conditions and can cater for this, also the engine cools faster than a water cooled engine when you run low throttle settings.
Postby Boet » Sun Feb 01, 2009 6:42 pm
Tandemtod, at least another right minded advise-giver. Thanks for the explanation. With premix the mix is only working at its optimum when the engine is running BTTW. At lower power settings and at idle, it is buggering up the spark plugs. With autolube the mix is always at the optimum. Saves oil and your spark plugs will last far longer.
We HAVE been over this countless times, but for those who missed it or have bad short term memory loss......
Air cooled engines : API spec "super chainsaw"Water cooled engines : TCW 3 "super outboard plus"
THAT IS WHAT THE BOOK SAYS
Do not try and be smart, DO as the book says. Maybe your engine will last longer. :wink:
