Aircraft Batteries
kobusf
Aircraft Batteries
Postby kobusf » Mon Jan 05, 2009 1:48 pm
Is an aircraft battery a standard 12v battery (same as motorbikes etc) or a special type?
Kobus
Stephan van Tonder
Re: Aircraft Batteries
Postby Stephan van Tonder » Mon Jan 05, 2009 1:49 pm
Most use a dry cell so no not quite the same as a car as it has no liquid acid. They are also a lot smaller to save weight.
kobusf
Postby kobusf » Mon Jan 05, 2009 1:57 pm
Thanks Stephan
Postby Morph » Mon Jan 05, 2009 2:52 pm
Yes you can use the same batteries, typically they are 12 to 17amp hour batteries. I would definately use a sealed battery. It all depends on the size of the battery holder
There are some folks who swear by the deep cycle batteries but newer engines' starter motors are light weight and quite happily operate on a standardd sealed lead acid.
the Panasonic LC-RD1217P 17 amp hour is perfect
Voltage: 12 V
AH: 17.0 AH
Length: 183mm
Width: 76mm
Height: 168mm
Weight: 6.8KG
ZAZU
Postby ZAZU » Mon Jan 05, 2009 4:45 pm
Morph, 2 questions:
1: The Rotax 912 requires a 18A/h battery, this is just short of that, is this a problem?
2. The cost of this battery?
Christo J/v Rensburg
"To be legal, you need the law;
To be just, you need a value system"
Oupa-G
Postby Oupa-G » Mon Jan 05, 2009 7:33 pm
Dear Morph and Zazu
The bat advised by Morph is excellent it is of the AGM Absorbed Glass Matt design . Its spongy lead plate design gives high amp abilities for starting. The amp capacity is not the alpha and omega it is the electricity supply ability during starting. The CTSW handles the starting of a 912S with a 7amp/h AGM battery
The bottom line is the more modern AGM design bat has a longer shelf life . It can absorb a tremendous charge rate so the charge rate of the alternator and a flat AGM bat must be matched. The old generator's can't handle flat AGM batteries. So do not get mixed up with cheap gel bat and the top class AGM Bat. The quality also reflects in the price but it eventually is cheaper because they last longer
Hope this helps a bit
Cheers Oupa-G
Postby Morph » Tue Jan 06, 2009 8:43 am
ZAZU wrote:Morph, 2 questions:
I am using a 17a/h and it is more than enough for a 912. I flooded my engine once at Saldanha and it took quite a bit of cranking to eventually start her and the battery performed perfectly
I bought one recently from Aviation Engines for about R450 IIRC. Any battery supplier should be able to source these
ZAZU
Postby ZAZU » Tue Jan 06, 2009 8:57 am
Dankie Menere!!
