Turboprop powered trike?
- Cloud Warrior
- Top Gun
Microjet in the UK have developed the HFTP Turbo-Prop Engine producing up to 130HP. Whose's going to take the plunge and try that on a trike?
Re: pictures
you need to first store the pic somewhere on the internet. Your ISP will usually give you a place to save them. Assume you have a place called www.mwebpics.co.za/powerfly/pics and the pics name is mypic.jpgpowerfly wrote:how do you post pictures?
then you select the Img block above, which will put in a [img]follow%20this%20with%20the%20url%20i.e.%20http://www.mwebpics.co.za/powerfly/pics/mypic. ... give%20you[/img]. By selecting preview you can see if it's working. once happy select submit.
