What type of radio?
Trikenut
What type of radio?
Postby Trikenut » Fri Aug 22, 2008 1:51 pm
Hi All,
Just a question out of interest. Which is better on a trike, a handheld radio e.g. Vertex 220 or a panel mount?
Trikenut
"Beware 16 year old here"
coastwise
I hate bird strikes
I hate bird strikes
Re: What type of radio?
Postby coastwise » Fri Aug 22, 2008 2:33 pm
Where exactly would you try and fit a panel mounted radio on a Trike, size wise not practical.
Aviate Raptor
Trikenut
Postby Trikenut » Fri Aug 22, 2008 3:59 pm
coastwise wrote:Where exactly would you try and fit a panel mounted radio on a Trike, size wise not practical.
Hi Coastwise,
You can fit them to trikes such as the Aiborne and Cobra.
Some info please!
Wargames
Postby Wargames » Fri Aug 22, 2008 4:32 pm
Why you want a panel mount??
You take handheld home and listen to ATC and other aircraft.
No contest.
ZULU1
Postby ZULU1 » Fri Aug 22, 2008 6:07 pm
Simple answer, VXA 220 and a 9.6 volt power supply. No debate. Only one thing needed that we have learnt with Vertex, we use a Binder 710 4 way jack/socket to hitch up the intercom. The continual unscrewing trashes the cable after a while. It is the BEST radio we have ever used and sold. Far better than most small panel mounts. Icom have lost the plot.
A VXA 220 with a Vee rabbit antenna on a trike will give greater than 200kms, very good noise 'elimination" it does everything just as it should do....Try that with a Microair.
Zulu1
Trikenut
Postby Trikenut » Sun Aug 24, 2008 5:04 pm
Thanks all that have commented.
Any more info?
Postby John Boucher » Sun Aug 24, 2008 6:06 pm
Listen to ZULU1 - he's the man!
AndyG
Postby AndyG » Mon Aug 25, 2008 8:02 am
Just question Trikenut. You have asked questions on engines, wings and now radios. Are you building a trike with a combinations of all the answers you receieve? :lol:
How's the training going?
Trikenut
Postby Trikenut » Mon Aug 25, 2008 12:06 pm
No, sorry.
Just want to find out all this interesting stuff! vhpy
Sukkelaar
Postby Sukkelaar » Tue Aug 26, 2008 8:53 pm
Hi there Zulu
I have above-mentioned radio,
Spoke to agents and have it connected to trikes 12 volt output( maybe a bit more)
with no problem.
I find it a hassle to remove airial all the time so lately I have been leaving it on trike.
Please advise on binder 710 jack and where it can be bought
Sukkelaar
Kyk Noord
ZULU1
Postby ZULU1 » Wed Aug 27, 2008 7:46 am
OK, The VXA 220, 300 and 710 all will accept a input up to 15 volts, we manufacture power supplies set to 9,6 volts and are user adjustable inside, they also include line chokes and other noise reduction devices. The regulators (LM338) are designed to have a voltage differential of approx. 1,5 volts. It is desirable to make this differential as wide as possible. The line chokes and regulator then delivers a very smooth supply. Although I may add the Vertex radios are in a far superior league to other units in this respect anyway.
Secondly, we have found that by user reducing the power supply down to say 6,8 volts it reduces the power output of the radio, when used locally with the Vee Rabbit antenna they actually swamp other frequencies and even car radios. So if flying a long trip and you want serious transmission power you simply remove the power plug. Then plug it back to deliver about 0,9 watts which is ample for up to about 80 or so kms. That way you can utilise the reception capabilities of the Vee rabbit antenna.
Binder plugs, i have been importing ourselves as we also use them on water coolers for bomb suits and I can supply a limited few. Demon will be supplying me in the near future and I would imagine he will be happy to supply direct. Also try RS components as they possibly stock them ? They are great as they can be linked direct to a headset also and very small. This "fix" sorts out the constant removing by unscrewing the plugs. Whilst on the subject, I have searched the world and the best replacement Vertex plug is actually the CT91 as they are cheaper than the CT96 and you just chop off the ends. The VXA is directly compatible with the older ICA3,22,4 5,23 series as its 4 wire and the input circuitry is very similar. It does not give rf hassles as the ICA6/24 series does.
Great radios, nothing in the same league, even panel mounts and they have user adjustable tone controls... and I am supposed to be a Icom dealer !!
Ciao Zulu1
Postby Tumbleweed » Wed Aug 27, 2008 2:38 pm
Luv it when you talk foreign.
Jag Air 124.4
Postby Jag Air 124.4 » Sat Oct 25, 2008 6:06 pm
hi zulu great speech but i just want to ask you something. how can i improve my vertex 220's signal on the ground?
thanks man!
