Rails to push trike sideways into hanger
Cacofonix
Postby Cacofonix » Fri Jul 18, 2008 7:17 am
:? Guys please help. My friend has build a hanger but the trike needs to be put on a rail and then pushed in side ways. Anyone with a plan :?:
ZU-EJU
Koevoet
I hate bird strikes
I hate bird strikes
Re: Rails to push trike sideways into hanger
Postby Koevoet » Fri Jul 18, 2008 8:03 am
Just a thought : Have a look how they installed a sliding gate (not the hanging one in garage door's)
They use 50 x 50 angle steel in the mortar or ground (part running on the ground) and sliding gate castors on the trolley (Gate), can not see why it cannot work - get decent castors - not small one's - break, wear to soon, stuck.
NB : attach or secure the 2 rails to each other so that the distance between them does not change (every 2-4m with a rod or flat steel)
Very happy Scout Piloooot
Massimo
Postby Massimo » Fri Jul 18, 2008 8:54 am
Peter i had something like this manufactured for my hanger on the farm. It works great. Used 2 angle irons that were concreted into the floor with the V facing up. The angles are the rails and run from the inside of the hanger to about 4 meters on the outside of the hanger. Then i made a cart that runs along the angles. So i drive the trike onto the cart and then push it into the hanger side ways. Ill try make a sketch and post ltr.
Koevoet
I hate bird strikes
I hate bird strikes
Postby Koevoet » Fri Jul 18, 2008 9:17 am
New it was something like that, i saw one that was bolted afterwards, on to the contrete, but works on the same principle as yours (Massimo)
Thax Massimo
Cacofonix
Postby Cacofonix » Fri Jul 18, 2008 2:57 pm
thanx massimo looking forward to the sketch vhpy
ZU-EJU
BOATCH
Postby BOATCH » Fri Jul 18, 2008 2:58 pm
I also used the same princ but on a very hot day they tend to move a little,so i took the wheels of and made them so they can move sideways on the axel and that 5mm side play on eatch wheel is there so the can stay on the tracks on a hot day.What also works well is when the wind picks up and you are allone you can drive the trike onto the trolley and with your one foot push it into the hanger and remain seated ,the best shape is a T shape trolley.
Cacofonix
Postby Cacofonix » Fri Jul 18, 2008 2:59 pm
ZU-EJU
3wheels
Postby 3wheels » Fri Jul 18, 2008 7:10 pm
Check out the setup that vliegvark has on "aircraft for sale"
This looks like what you are looking for :wink: I'm sure he could help you out with the plan.
Aerotrike 503 **SOLD**
by vliegvark on Thu Jun 05, 2008 11:23 am
ZU-"Charlie"YV
Cacofonix
Postby Cacofonix » Sat Jul 19, 2008 6:42 am
Ja i checked it out. vhpy I have sent vliegvark a pm. Thanks i know that with all your inputs we will nogal have a smart "Trike Cart Docking Station" Common Massimo, gooi the design.
ZU-EJU
grostek
Postby grostek » Sat Jul 19, 2008 8:14 am
Hi peters,
Here is a sketch of a rail system I made this morning ,
not complete but should give you a good head start.
Kind regards,
Gunter Rostek
Trike Trolley A.pdf
File A
(23 KiB) Downloaded 298 times
Trike Trolley B.pdf
File B
(6.16 KiB) Downloaded 306 times
Cacofonix
Postby Cacofonix » Sat Jul 19, 2008 6:30 pm
very very nice...this is gonna be and awesome docking station vhpy Thanks Gunter the guys are down loading :lol: what a a help ^*^^
ZU-EJU
grostek
Postby grostek » Sat Jul 19, 2008 6:40 pm
Glad to help.
Kind regards,
Gunter Rostek.
Massimo
Postby Massimo » Mon Jul 21, 2008 10:55 am
Here you go Peter. Just a simple sketch. Sorry for the delay.
20080721121353074.pdf
(67.86 KiB) Downloaded 293 times
Dobbs
Postby Dobbs » Wed Jul 23, 2008 5:29 pm
Peter, I have one which I used when sharing a hangar with a Gyro, my plane is a Windlass, now that I have my own hangar it is no longer used and you are welcome to have it, only problem, it is down here in Empangeni
Dobbs
Dobbs
Postby Dobbs » Wed Jul 23, 2008 5:30 pm
OOOPs cell 082 895 2009
Dobbs
