Radio interference
Leprachaun
Radio interference
Postby Leprachaun » Mon Sep 19, 2005 1:57 pm
Hi Guys , the Leprachaun out there are starting to get on my nerves .
My Radio Icom a5 suddenly started getting the worst radio interd-ference you can get - The noise is similar to plug noise at high revs - never done it before - Where do I start
Regards Leprachaun - ZU - DGB :roll: :wink:
Postby Morph » Mon Sep 19, 2005 2:23 pm
Hey Leprachaun
This is discussed in great detail here
http://microlighters.co.za/viewtopic.php?t=202
Postby Tailspin » Tue Sep 20, 2005 9:00 am
I noticed if there is a bit of a shitty connection on your spark plaug wires that can also cause some interferance.
DarkHelmet
Postby DarkHelmet » Tue Sep 20, 2005 10:33 am
Have you recently changed plugs? I had a similar problem, manual states B8ES for my Rotax 582 (form there the noise) but I was recommended to install BR8ES.
JBurger
Radio Interference
Postby JBurger » Tue Sep 20, 2005 3:18 pm
The correct spark plugs is very important and from experience on my 503 I know that only BR8ES works.
I had proplems with noise on my Icom A22 on a few occations just to find that somehow I managed to switch off the automatic noise reduction (ANR) on the radio. This filters out most of the ignition induced noise and will normally let your radio perform much better. Check if the noise reduction is switched on as it might be all that is wrong
kb
Re: Radio Interference
Postby kb » Tue Sep 20, 2005 3:26 pm
JBurger wrote:The correct spark plugs is very important and from experience on my 503 I know that only BR8ES works.
DITTO DITTO DITTO :lol:
Leprachaun
Radio noise
Postby Leprachaun » Thu Sep 22, 2005 12:24 pm
Hi Guys, thanks for the comments and help - Problem solved - Multivectorial - Aerial was realianed , cleaned bowspirit mounting , all earth connections and readjusted internal squelch - and ditto - alls well that ends well ,
May the Leprachauns protect ya :roll: Guiness is good for ya
ACE
Re: Radio noise
Postby ACE » Thu Sep 22, 2005 3:15 pm
Leprachaun wrote:... Guiness is good for ya
Yes, go here:
http://microlighters.co.za/viewtopic.php?t=759
...page three, photographic evidence,, Demon busy converting lots of this stuff into p#ss :D :D
Well done on sorting out the radio gremlins, often it's not located to one area, but several of them at the same time. :!:
A Smith & Wesson beats five Aces
krusty
Postby krusty » Thu Sep 22, 2005 4:07 pm
demon wrote:lp:
And Kilkenny is even better 8) :? (^^)
Aye Aye Cap'n
http://www.adultlounge.co.za
Leprachaun
Radio noise
Postby Leprachaun » Fri Sep 23, 2005 8:22 am
Top of the morning to the captn an others - Maybe we should meet and have a tasting contest -
Kilkenny - Guiness /Tullamore Dew and a couple others .
The Leprachauns will definately take care of ya all (^^) :-(-( -0<
Will arrange for a meet at the Fairie ring at the Forest in Dingle - Weather is a bit shitty but will be there in Dec ember visiting the family and enjoying the good iIrish hospitality - will be doing some flying near Kells
