Oil on the hangblock?
DarkHelmet
Postby DarkHelmet » Sun Sep 11, 2005 8:41 pm
The hangblock assembly on my aerotrike safari with Spirit 2 wing has an odd creek to it.
Is it a bad idea to oil it with some Q20?
IFLYHI
Postby IFLYHI » Mon Sep 12, 2005 9:47 am
If there is a danger of a grinding paste forming (oil and dust) rather try something like Dry Lube from Spanjaard
alan
Hangblock
Postby alan » Mon Sep 12, 2005 12:17 pm
Best is to use a puff of graphite. Just slide the hangblock back or forward and give it a puff of graphite. Stops the creeking. Don't use oil as it makes a mess and abrades the hangblock :?
Waiting for the wind to stop
DarkHelmet
Postby DarkHelmet » Mon Sep 12, 2005 12:21 pm
Graphite? Not the same as in pencils? I read that this adds to the corrosion of Aircraft aluminium... Never write on yer metal with a pencil I recall?
alan
Hangblock
Postby alan » Mon Sep 12, 2005 12:51 pm
Not sure about the graphite corroding the aluminium but the sleeve that goes through the hangblock is steel in the trikes I know of :roll:
Junkie
Postby Junkie » Mon Sep 12, 2005 6:31 pm
:shock: =; (**) :-(-( Whoa hold them hosses cowpokes!!
No oil or graphite on ally. just end up catchin all the dust and before long you'll have a nice black smudge and a wearing part right were u dont want it. Best to leave it dry if you can
You MAY use a tiny bit of LITHIUM based grease when assembling the wing or putting on a new hangblock etc, but dont smear it on after the fact and try to work it in
With the lectric actuator installed, ive found best to just run it dry - it bothers me too, but its the lesser of the evils
Maybe steel sleeved keels will be ok i guess
J.U.N.K.I.E 's
No credit / No returns
