help pleeeeaaase
soekiwindni
help pleeeeaaase
Postby soekiwindni » Mon May 12, 2008 8:58 pm
I know this topic was raised once to many, but pleeaase.......... :oops:
Everyone I know changed from Super Chainsaw to Super Outboard and adviced me to do the same......DADELIK.
Why??
Does Super Chainsaw cause rings to get sticky and carbon ?
Please don`t give me all the technical details as it will only confuse me even more (I did read the technical site refered to on this forum ($$) )
All I would like to know is which 2 stroke oil must I use in my 503; Super Chainsaw or Super Outboard and why.
Thanks for all the input on this forum.
Jodie
I hate bird strikes
I hate bird strikes
Re: help pleeeeaaase
Postby Frequent Flyer » Tue May 13, 2008 8:28 am
tricky one - but i use super outboard on my 582 and 503 because i cant get super chainsaw in kuruman @ all. my 2c worth
Stephan Du Plessis
Freq 118.90
FAGG - RW 11/29
082 921 5396
Postby Morph » Tue May 13, 2008 11:44 am
Super Chainsaw is recomended for the 503, because it is designed to handle the much higher operating temps of an aircooled motor. Super Outboard is designed for use in a watercooled motor, i.e. 582. There is a significant difference in the engine temps
CHT
503 180 to 220 deg C
582 110 to 130 Deg C
However that said, My 503 ran on Super Outboard for 200 hours by the previous owner.
What is considered a problem with carbon buildup. I dekoked my 503 for the first time at 500 hours? Is this a problem or do you expect the engine to run it's full life without a decoke.
Hours 1 to 200 no idea what oil was used. 200 to 440 Super Outboard, 440 to 600 Super Chainsaw
BTW decoking the motor is piss easy to do, just takes a bit of time so what's the big issue
LarryMcG
Postby LarryMcG » Tue May 13, 2008 12:34 pm
Most Guys in the Eastern Cape use Castrol Super outboard. Decokes show very good, clean results. Better corrosion prevention.
Still Flying
I hate bird strikes
I hate bird strikes
Postby Frequent Flyer » Tue May 13, 2008 2:33 pm
ditto on the decoke - on my 582 300hr overhaul (bad old days vhpy ) the carbon build up was minimal :!:
Stephan Du Plessis
Freq 118.90
FAGG - RW 11/29
082 921 5396
soekiwindni
Postby soekiwindni » Wed May 14, 2008 9:40 pm
Thanks!!! So Super Chainsaw it will be for the next 700 hours.......... vhpy
Jodie
Carel
Survived first engine out
Postby Carel » Thu May 15, 2008 7:02 pm
Morph,
Please eloborate on the piss easy time consuming decoke. Would like to know how.
Postby Morph » Fri May 16, 2008 10:47 am
Carel wrote:Morph,
viewtopic.php?f=13&t=1851
You just need head gaskets, the aluminium gaskets that go between the sleeve and the crank case, and the inlet and exhaust gaskets. Then about R200.
