Oil Injection for 582
Flightstar
Postby Flightstar » Tue Jan 15, 2008 12:22 pm
I have a new blue top 582 fitted to my recently built Challenger.The engine hangs upside down . It was fitted with an Oil Injection unit. The unit was installed correctly and all lines and marks were lined up correctly. The unit however delivered way to much oil, as much as 1,25 litre per 25 litres of fuel.
After discusions with Gideon Niemann the injection unit was replaced with a new one kindly supplied by Aviation Engines. The situation remained unchanged however. Gideon has removed the unit in the meantime to enable me to complete the hours for the proving flights on the Challenger, using pre-mix.
The aircraft now has 39 hours on the Hobbs and I would like to re-install the oil injection unit again. I would appreciate advice and comments on how to rectify the problem that I am experiencing.
And please the discussion is not about the pro's and cons of oil injection and pre-mix :wink: :roll:
Derick.
Ch 701 Skyjeep (ZU-DPN)
Postby Morph » Tue Jan 15, 2008 3:44 pm
I do seem to recall there was an idiosyncrasy regarding the inverted installation. I picked this up off the web
http://www.rotaxservice.com/rotax_parts ... alight.htm
http://www.rotaxservice.com/rotax_tips/ ... ection.htm
Installation criteria
The tank should be placed so that its outlet is always higher than the pump under any flying attitude, so that the pump is always gravity-fed
The oil line and oil filter have to match Rotax standards
A few precautions have to be taken during the first run: It is important to bleed the system to free any air bubbles; the oil injection lever cable has to be adjusted so that the marks on the lever and pump align at idle; the first tank should contain 100:1 premix to ensure that the engine will receive adequate lubrication while any last air bubbles go through
Postby Morph » Tue Jan 15, 2008 3:52 pm
As far as pro's and cons are concerned
My opinion is that technically oil injection has stood the test of time, is reliable and efficient and works well. If you have it use it.
I personally never had one nor felt the need to install it as premixing was never a schlep to me.
Lurker
Postby Lurker » Tue Jan 15, 2008 4:33 pm
Morph you got PM. Thanx
A mile on the road will take you a mile.
A mile of runway will take you anywhere!
Flightstar
Postby Flightstar » Thu Jan 17, 2008 4:32 pm
Thank you Morph.
As a previous Challenger owner I have to ask you : Are you aware of anyone succesfully mounting a fourstroke motor to a Challenger?
Derick.
Postby Morph » Thu Jan 17, 2008 6:02 pm
Yes, HKS four stoke, 65 hp I think.
Have a look here
http://www.challengers101.com
and http://challenger.inebraska.com/modifications.htm
and http://www.ultralightflyer.com/airventu ... ngine.html
You won't be able to install a 912 due to it's weight and too much power for the Challenger
