Gentleman
Where can I obtain a fuel flow sender, except for MGL.
MGL does mention that you can use an automotive fuel flow sender, but I can't find one at any of the local parts, diesel or Bosch centers.
Also, which type of level sender would you recommend? You get the type with an arm and also the tube type. I think the latter would be more accurate?
I'm just weighing options at this stage.
Fuel Flow Sender
- Barnstormer
Fuel Flow Sender
Planeless...
- ZULU1
Flow Meter
Try RS Components, they courier and have a serious quantity to choose from:
http://www.rssouthafrica.com
Try part # 185 9982
Failing that try Farnells (Google it) and the local agent is Mantech, for costing take the £ price and multiply x 17 for ZAR.
Eish Zulu1
Try part # 185 9982
Eish Zulu1
- Barnstormer
Thx Morph!
Tube will thus be best for my tanks.
I do not have a problem with the MGL sender. However, they mention that a normal automotive unit can be used. I thought there would be a good reason why they mention this. Price maybe? But, yep there is almost always a but, finding said sender at a automotive supplier seems to be something of a mystery (misery).
Thank you for the reply! I was hoping YOU would. :D
Also, thank you for pointing out that resistive is the way to go.
Mr Zulu!
One of the other distinguished gentleman I was hoping to get a response from!
I appreciate your advice and will follow it.
Greetings!
Mr Zulu!
Greetings!
Planeless...
Here are some options
Optifuel http://www.optifuel.co.za
Floscan http://www.floscan.com/html/blue/aviation.php
I cant find any references to automotive units which is probably why Rainier from MGL made his own
Fuel level senders are available from VDO's local distributor or your nearest spares shop. (Control Instruments http://www.control-instruments.com) Call them, maybe they have fuel flow senders as well
- Barnstormer
Hi Guys!
The following places do not stock fuel flow senders and can't get their hands on it either. (Any type we can use)
Control Instruments
Autozone
Bosch Centres
5x Diesel and Auto Electrical places I tried.
I am still to try Elpar. Control Instruments does the complete range of VDO. The friendly gentleman there advised me to try Elpar for a better price on a VDO fuel LEVEL sender, as Elpar might buy bigger quantities. As Morph said, they also recommend the tube type above the float type.
I even contacted a friend at BMW. The cars do not use fuel flow sender to calculate fuel consumption, they use more advanced and fancy methods which I am not capable of explaining. Basically it is about pressure, flow of mixed gas, amount of air etc.
Greetings and thank you for the comments.
Control Instruments
Autozone
Bosch Centres
Planeless...
