To Auto-Lube or To Pre-Mix ???
Auto-Lube or Pre-Mix
Auto-Lube
7
35%
Pre-Mix
13
65%
Total votes: 20
Aquillaguy
Postby Aquillaguy » Mon Aug 08, 2005 10:41 pm
I have tried to find any forum worldwide talking about Autolube related Engine Failures....Could not find anything whatsoever...?
Seems to be a regional debate in S.A. ...Coastal flyers predominantly pre-mix,inland Autolube...
What's the concensus... ?
Any comments....?
Myself ~ Unleaded Autolubed with CSCS on 582 ~
8)
You're alive, so live.
Extreme Freedom!
DarkHelmet
Postby DarkHelmet » Mon Aug 08, 2005 11:28 pm
Personally I have been schooled on pre-mix - less points of failure...
Aerosan
pre mix
Postby Aerosan » Tue Aug 09, 2005 6:29 am
I agree pre mix has less points of failure, you know the oil is in the feul and exactly what the mix is.
my 2 cents
:D
Postby Morph » Wed Aug 10, 2005 9:28 am
Yep, premixing is part of my ritual, and I never have to worry about running out of oil before I run out of fuel. Less points of failure, and not at all inconvenient. I don't see the need to change
Cloud Warrior
Postby Cloud Warrior » Wed Aug 10, 2005 10:50 am
Autolube is absolutely the way to go! :wink:
Actually I don't have any choice seeing as I bought my trike with autolube as part of the package anyway! :oops:
Having now spent a bit more time around trikes and listened to wise old men :twisted: it would seem that autolube does have its faults e.g. pump does not work 100% of the time e.g. during approach when you have reduced engine revs?
In hindsight I would rather mix my own fuel/oil and then I know it is right!
skybound®
Postby skybound® » Wed Aug 10, 2005 12:56 pm
So only people against so far!
Some Pros about Autolube-
  • Correct mix is delivered at all times. PreMix is set for full power, so at anything less is too rich.
  • Shorter Shelf life of mixed fuel
  • Less carbon build up
  • Can almost refuel anywhere - no need to carry pre-mix or fuel can on long journeys.
RudiGreyling
Postby RudiGreyling » Thu Aug 11, 2005 11:11 am
Old Engineering Principle:
All things considered equal, adding 1 extra component in a system inceases the likelyhood of failure exponentially in the system .
My motto: KISS...Keep It Simple Stupid.
http://www.RudiGreyling.com
Autolube.
Postby Boet » Thu Aug 11, 2005 8:37 pm
What I consider really bloody stupid, is people REMOVING an auto lube system from a Rotax engine. You PAID for the thing meneer, so USE it. It is not troublesome in any way. Will only be so if you pour contaminated oil or the wrong grade oil, or FORGET to pour oil in. Very good system. Go for it. :D :D :D :D :D
Pepper
Postby Pepper » Sat Aug 13, 2005 8:37 am
I have to agree with Boet, good system that always gives the corect amount of oil. Only if you don't do your preflight checks anymore should you worry about running out of oil before running out of fuel.
DarkHelmet
Postby DarkHelmet » Sat Aug 13, 2005 11:17 pm
You get time to boat?
Autolube or not
Postby Boet » Sun Aug 14, 2005 7:43 pm
And it provided with a low oil warning switch, for the slapgat preflighters. I notice that us "autolubers" are heavily outnumbered by the "premixers". Surely then a lot of autolube systems must be gathering dust all over the show. If the price is right, I want one! :D :D :D :D :D :D :D :D
Slurp
Found a flight school
Postby Slurp » Tue Aug 16, 2005 1:18 pm
Boet,
Sorry but you don't know what you're letting yourself in for. I had a seizure at 180 hours due to autolube failure. When I sent my unit into Rotax for analysis, they "lost" it.
There are plenty of stories.
Bottom line, the less there is to go wrong the better. I feel much better with pre-mix cause then I know its right!!!! (-)
Great day for flying with the one-eyed-dick!!!
Postby Tailspin » Tue Aug 16, 2005 1:25 pm
I think premix is the better way to go, the AUTOLUBE system is just one more thing to go wrong that is working in the back of my mind while flying - heard too many stories =;
C205
Postby C205 » Tue Aug 16, 2005 1:37 pm
My instructor believes in pre-mix for exactly those reasons. Makes sense.
Quicksilver MXII ZS-VAP
Quicksilver MXII ZU-BOW
FAWI 123.5
Postby Tailspin » Tue Aug 16, 2005 1:51 pm
Demon
One day when the Mom lets me play with the other boys i will get a 4 Stroke :lol: :lol:
