Anti-Freeze
Kobusjvr
Anti-Freeze
Postby Kobusjvr » Fri Jul 15, 2005 10:16 pm
Which anti-freeze would be good for use in a Rotax 582 coolant?
zoofly
Postby zoofly » Sat Jul 16, 2005 10:23 am
I have always used Mercedes Benz
MB Antifreeze & corrosion inhibitor
for both 2 and 4 strokes.
Mixed 70 parts MB to 30 parts water
Abe
Postby Abe » Sat Jul 16, 2005 10:22 pm
Kobus, wees versigtig met antifeeze!
Rattex waterpump seals are notoriously unforgiving of abuse, a leak can ruin your day and if you do not notice water getting in the oil it will get expensive.
If it does not say glycol, it is not.
I only use Castrol GLYCOL antifreeze at 50% dilution, probably the same stuff Mercedes sells at twice? the price.
Very important: only dilute with real distilled water. Rand Water Board adds limestone to piped water to protect their iron pipes, but it deposits calcium carbonate in water-cooled systems which clogs radiators and eats rotary water seals.
Junkie
Postby Junkie » Tue Jul 19, 2005 7:51 pm
Always used the VW product (anti Nitrate) with no hassles (blue in colour) running about an 80:20 mix to water. No problem with our local water quality as is.
VW have recently changed to a different formula (its now pink) so ill let you know if it comes up short on expectations.
J.U.N.K.I.E 's
No credit / No returns
skybound®
Postby skybound® » Wed Jul 20, 2005 12:45 pm
Had two 582's that I cracked about two weeks apart. One with 150 hours and the other just over 300 hours.
The 300 hour one had used a green mix, which I believe now to be a cheap offering at Midas and branded with the Midas colours. It mixes 3:1. There was not a single scale or deposit in the water jackets.
The 150 hour one had used another product and even with half the hours was messy inside with scaling etc.
There is also a lot into using the distilled water - not the battery stuff but the hospital distilled type water. Don't drink it however.
Antifreeze
Postby Boet » Sun Aug 14, 2005 7:56 pm
Skybound, you don`t DRINK water. You wash in it, the closest is when you brush your ivories. Drink BEER. :lol: :lol: :lol:
Bacardi
Postby Bacardi » Sun Aug 14, 2005 8:17 pm
Bacardi
Postby Bacardi » Sun Aug 14, 2005 8:18 pm
grosvenor
Postby grosvenor » Sun Aug 14, 2005 8:24 pm
I would trust Abe on the "water" thing - if any body knows about good and bad water, it's him!
And why not drink hospital distilled water? Apart from the cost?
W
skybound®
Postby skybound® » Mon Aug 15, 2005 9:51 am
grosvenor wrote:And why not drink hospital distilled water? Apart from the cost?
W
I believe it will land you in hospital :!: With all the natural bits taken out of it, I believe it is almost like drinking poison.
