Wing balanse out
Bennie Vorster
Wing balanse out
Postby Bennie Vorster » Sat Sep 30, 2006 3:37 pm
Since I reasembled my wing after transporting it, the left hand wing start forcing downwords when I fly and the bar is off center. It is also not as light as prevuisley, who of the pro's out there can tell me what is wrong?
Bennie Vorster
083 277 5110
Tjoek
wing
Postby Tjoek » Sat Sep 30, 2006 7:48 pm
Bennie,
For starters I would check that my battens are still correctly shaped. Get a batten chart, and ensure that all are within spec.
Then I would trim the wing for hands-off straight flight. Turn the wing tip caps small bits at a time (1mm), and test fligh after each adjustment in good weather. By lowering a tip trailing edge. that wing tip will create more lift, and vive versa.
Bennie Vorster
Postby Bennie Vorster » Sat Sep 30, 2006 9:31 pm
Thanks Guys, Ill check and feed back. :wink:
Bennie Vorster
083 277 5110
DarkHelmet
Postby DarkHelmet » Sun Oct 01, 2006 11:13 am
Hi Bennie, I had a similar problem - turns out I put the left battons in the right...
Bennie Vorster
Postby Bennie Vorster » Sun Oct 01, 2006 8:06 pm
DH
I Got a feeling that it just might be my problem as well. :? But the wind is howling today so I'll check it during the week. :roll:
Bennie Vorster
083 277 5110
Bennie Vorster
Postby Bennie Vorster » Mon Oct 16, 2006 10:46 pm
Ok, it seems like the problem is sorted.
Did you guys know that on the windlass wing you can add or remove spacers at the tip of the wing to either tighten or loosen the wing material tension to create more or less drag on that side of the wing to compensate for the lift to the lack there of. :roll: :roll: :roll:
Bennie Vorster
083 277 5110
