Choosing a propellor - advice please!
Bullit
Postby Bullit » Tue Jul 14, 2015 7:24 am
Hi all.
Does anybody have any experience with the Warp Drive 72 inch 2 blade propeller? Available from Comet for just over R5K (http://cometaviationsupplies.co.za/inde ... ct_id=2113
I have A Rotax 503 DCDI and the choice of either a b- or a c-gearbox - have one of each. Together with that I also have a Pieter de Necker wood prop - 63x34 if I remember correctly. The prop has a small crack in the trailing edge, but I am sure it can be repaired - still have to confirm and get a price for that.
The engine/gearbox/prop will go on a Scout cart with Windlass wing, which I am busy rebuilding (She went back on her wheels this past weekend vhpy)
I need to choose between repairing the P Prop and use with b-box (because I have it and will likely cost me the least to get into the air, but will performance be OK?), get a Warp 2 blade to use with the c-box (because it is a really good price, but I cannot find any info on it's performance), or get a new NC or P Prop (proven, but expensive).
What would you do?
Martinvt
Re: Choosing a propellor - advice please!
Postby Martinvt » Tue Jul 14, 2015 7:47 am
I will defnitely go for the c-box with the NC prop. We have a scout flying in potties with a e-box and a NC prop and it flies extremely well.
It is expensive but worth the money.
The ratio of the e-box on Willie's scout is 3,47.
Martin van Tonder
Aerotrike Safari
ZU-CIE
meglin
Postby meglin » Mon Aug 17, 2015 12:34 pm
Hi Bullit!
We have two-bladed propellers are used very rarely.
All switched to three-bladed propellers.
They are always quieter and more comfortable to use.
For Rotax 503 with gear B 1 / 2.58, I recommend a three-bladed 1600 mm 63 ".
There is an option with straight blades and Sabre.
Sabre has certainly quieter and pull her up.
But it is more expensive - 540 €.
Straight blade - 450 €.
The maximum thrust of 140 kg (standard conditions).
In the case of third gear can apply a three-bladed propeller diameter of 1700 mm.
Link will reach 145 kg.
Only in the case of the gear 1 / 3.47 can be applied three-bladed propeller of 1750 mm 69 ".
Link to nearly 150 kg.
Two-bladed propellers are also possible, but thrust them below, and the noise is always higher.
But they are cheaper.
Two-blade carbon propeller diameter 1820 mm 72 "Sabre is 430 € and direct 390 €.
However, the prices mentioned - just before the end of this season.
Another feature: Propellers large diameter will deteriorate with increasing speed.
They are only good at the start.
Best regards
Vladimir Meglinsky
My site: http://propeller.mozello.com/
Postby nicow » Mon Aug 17, 2015 12:39 pm
Wow,very nice picture... (!!)
meglin
Postby meglin » Mon Aug 17, 2015 12:49 pm
nicow wrote:Wow,very nice picture... (!!)
These are our countrymen in Nepal. They use a Rotax height adaptation.
Best regards
Vladimir Meglinsky
Bullit
Postby Bullit » Thu Aug 20, 2015 2:55 pm
Thanks Meglin
How much to ship to ZA?
And if anyone is interested - Contacted Warp Drive and they do not not recommend using this prop on a trike/503.
mulderpm
Postby mulderpm » Fri Aug 21, 2015 6:26 am
There is also Nigel Coats, NC composite props, in Johannesburg. Be aware of the import duties and shipping charges on imported aviation components.
Paul Mulder
Tailwinds are the best
ZU-DBC Aquilla
Pretoria
meglin
Postby meglin » Fri Aug 21, 2015 11:35 pm
Yes, indeed, delivery propeller in your country is 50 €.
Best regards
Vladimir Meglinsky
German
Postby German » Sun Aug 23, 2015 5:40 pm
Daar is net een prop en dit is n P PROP!!!
Bullit
Postby Bullit » Mon Aug 24, 2015 7:20 am
50 Euro for shipping a prop to ZA??
Sad-Ham
Postby Sad-Ham » Mon Aug 24, 2015 10:53 am
Beautiful trikes............ what make are they?
Aquilla II ZU-DJS
Wingfield - 124.8
greg vos
Postby greg vos » Thu Sep 10, 2015 7:23 pm
a nice pic and nice looking plane..but Im not sure I would fly over cloud?? not constantly knowing where I would land in the event of a technical failure? just saying.
PPL (A)
PPL (H)
CFI Gyro & Test Pilot
meglin
Postby meglin » Wed Sep 16, 2015 5:53 pm
Bullit wrote:50 Euro for shipping a prop to ZA??
Yes, 50 € is shipping to South Africa.
Best regards
Vladimir Meglinsky
meglin
Postby meglin » Fri Feb 26, 2021 1:13 pm
During this time, quite a lot of our propellers went to South Africa. I hope the owners are happy.
Best regards
Vladimir Meglinsky
