582 Coolant Color Change
Bateleur
Postby Bateleur » Tue Feb 04, 2014 11:28 am
I am most probably over reacting again, but I noticed on Sunday that our Aquilla 582's radiator water has changed from its normal light PINK color to a darker PURPLE color. I flew with her like that on Sunday and there was no drop in water level. It just doesn't seem right to me?
Could it be a problem?
Stef Oosthuizen
Step it up a notch!!
ZU DBP
Dunesand
Re: 582 Coolant Color Change
Postby Dunesand » Fri Feb 07, 2014 8:21 am
Hi Bateleur,
Have a look at my post 2 year ago.
viewtopic.php?f=13&t=17667
I had a similar problem with coolant discolouration without any engine problems whatsoever.
I am 90% sure mine was as result of some exhaust gas entering the coolant at the top gaskets as result of a little too low torque of the six nuts on the top.
A local guy phoned me up and said they have seen this happening in a vehicle - if the coolant changes colour, it might well be exhaust gas entering the coolant.
Strangely I also never had loss of coolant either and since I re-torqued the bolts a little bit higher, the discolouration hasn't appeared again after I replaced the coolant.
Whether your discolouration and my discolouration is as result of the same problem is difficult to say - maybe if you leave it a little longer the discolouration might be the same eventually - or maybe it has to do with the type of 2 stroke we use. I use CASTROL POWER 1 RACING 2T and the coolant is also CASTROL premix.
Hope it helps.
Bateleur
Postby Bateleur » Fri Feb 07, 2014 1:36 pm
Hi Dunesand,
Thank you very much for your comments. My first thought was also that it could only be exhaust gas mixing with the water, but I thought that in that case the water level should drop.
I am going to check this with Hans our AP at the airfield.
The cooled has done 110 hours now, so I think it is worth a flush and refill.
Thanks a lot, your input is highly appreciated.
Stef
Stef Oosthuizen
ZU DBP
