As a new owner of a used aircraft, and newly certified pilot I would like to ask of the more experienced guys out there about the true life of a rotax 582.
I am only asking opinions based on experience. My aircraft(bushbaby 95) is 10 years old in April this year and has 267hrs on it now, and I have only just found out about the
300hr life span of crank/piston assembly of my engine.(the 10year time also) My area to fly in until I do my cross country endorsement is only 25nm radius of our local field.
I am mainly flying over open fields an farms and will be staying away from our northern border hills. Has anyone found that these engines are longer lasting enough to keep using
safely for a bit longer, ie 10% to enable me time to save to buy a new one as the rebuilt item is almost as expensive if there is enough safe areas to put down in.
I don't know if the engine has had the servicing done as specified every 25hrs etc as the maintenance manual states for the log book is not filled in with many details.
It has been run on Castrol TTS oil and premium unleaded. I have had 16hrs time in transit when purchased where it did not miss a beat to bring it home.
rotax 582 hrs TT limitations
- KFA
Re: rotax 582 hrs TT limitations
The new Part 44 states that if the aircraft is privately used then it is on condition. So if the AP is happy to put his signature in the logbook then you are OK to fly. If you are still training and the ATF is a training ATF then you have to adhere to the maintenance schedule. The engine does not need a complete overhaul at 300 hr, only a decoke and crank inspection. But after overhauling a couple of 8 year old 582's I can guarantee you that at 10 years you have to replace the crank seals, gearbox seals and rotary valve seals. Also have a look at the bearings in the gearbox. Check for pitting on the cranck bearings, especially with an engine with those low hour's.
PS. The 582 has a 600hr and 10 years overhaul time that was approved by the Director a couple of years ago.
- New Maintenance Schedule 2 strokes.pdf
- (12.18 KiB) Downloaded 567 times
