Probably cause a lot of additional drag and also alter the a/c flight charactersistics by acting as a "wing"..... . it would also have to be pretty robust so would also increase the weight. Your wheels would still be the lowest part of the a/c and thus snag the wires regardless....What do you guys think of fitting all trykes with a belly skid plate that go with a curve angle up to center of wheel height of the back wheels that when the back wheels might get caught up in wires, it might slide across the belly of the tryke? It should also extend towards the back just passed the prop between prop to ground clearance so the prop can also clear.
