Radio Issue
bobthebuilder
Radio Issue
Postby bobthebuilder » Wed Nov 06, 2013 7:30 am
Hi Guys,
I have a MicroAir M760 Panel mount Radio.
In the circuit at Petit (133.20) and Rhino Park (135.6) it functions 5/5.
However! .......
It seems that while on SRE [125.4] and on SRW [125.8], I can hear all incoming transmissions perfectly, but my own transmissions are inaudible to SOME traffic.
When flying with friends, they say that my transmissions are 4/5.
It seems that my transmissions are received well by some aircraft, and poorly by others.
Can anyone advise on how to troubleshoot this problem?
Byron Kirkland
Re: Radio Issue
Postby nicow » Wed Nov 06, 2013 8:14 am
Check your antenna...
ZULU1
Re: Radio Issue
Postby ZULU1 » Wed Nov 06, 2013 8:38 am
Unfortunately Bob, i dont have enough information to help you out ?
When you visit a doctor and advise you have toothache it doesnt help !
So What aircraft
What antenna, where is it mounted and what ground plane if any?
What intercom system or are you using the Microair internal
What headsets are you using
The Microair has a side tone setting and also a power setting. I would advise if used in a trike its redeployed as a rather inefficient wheel chock..
Advise the above and i will see what i can come up with.
Re: Radio Issue
Postby nicow » Wed Nov 06, 2013 11:50 am
I also have a Microair on my Cobra,and it works much better than the handhelds on my other trikes...
bobthebuilder
Re: Radio Issue
Postby bobthebuilder » Wed Nov 06, 2013 12:02 pm
Hi Paul,
Aircraft: Super Koala
Antenna: Don't know what make it is. Bee sting type thing mounted on the roof of the aircraft. (Not the swept type)
Antenna Cable: Co-axial cable from the radio (panel mounted) which leads to the roof of the aircraft, more or less aligned with the the tailing edge of the wing. I estimate the cable to be around 1.8m long.
Ground Plane: Wooden airframe.
Intercon: Microair internal.
Headset: Peltor.
I will go out to the field on the weekend and take a photo of the antenna if required.
Many thanks for your assistance.
Byron Kirkland
bobthebuilder
Re: Radio Issue
Postby bobthebuilder » Wed Nov 06, 2013 12:04 pm
Nico, the best setup that I have ever had was a Vertex 220, with an Airmagic intercom and helmets with intergrated headsets. The system also used a V-Rabbit antenna.
Crystal clear transmissions every time.
Byron Kirkland
Re: Radio Issue
Postby nicow » Wed Nov 06, 2013 3:25 pm
bobthebuilder wrote:Nico, the best setup that I have ever had was a Vertex 220, with an Airmagic intercom and helmets with intergrated headsets. The system also used a V-Rabbit antenna.
I have 4 of them (!!)
bobthebuilder
Re: Radio Issue
Postby bobthebuilder » Wed Nov 06, 2013 6:19 pm
Guess there is a reason for that.....
Byron Kirkland
bobthebuilder
Re: Radio Issue
Postby bobthebuilder » Wed Nov 06, 2013 6:21 pm
Oh Paul, I forgot to mention ......
I use AirNav pro on a Galaxy Note cell phone. There is no GPS antenna.
Byron Kirkland
Re: Radio Issue
Postby Duck Rogers » Thu Nov 07, 2013 4:27 pm
bobthebuilder wrote:Hi Paul,
Byron...on my Koala the interior of the cabin roof had an aluminium plate as a groundplane, stuck/srewed to the interior of the roof lining.
bobthebuilder
Re: Radio Issue
Postby bobthebuilder » Fri Nov 08, 2013 5:03 am
Hi Gerrie,
I don't have an aluminium plate that is visible anywhere.
Could the instrument panel have been used?
Byron Kirkland
ZULU1
Re: Radio Issue
Postby ZULU1 » Fri Nov 08, 2013 8:43 am
Please take a pic of the interior of the cabin, that ground plane is law!
Re: Radio Issue
Postby Duck Rogers » Fri Nov 08, 2013 6:07 pm
bobthebuilder wrote:Hi Gerrie,
...or maybe the undercarriage....or an empty coke can.......who knows?
You gotta have a groundplane......else she won't work good :shock: ...if at all :?:
bobthebuilder
Re: Radio Issue
Postby bobthebuilder » Fri Nov 08, 2013 6:51 pm
Thanks guys, I now have a place to start. I'll take a look tomorrow and get some pics.
Byron Kirkland
ZULU1
Re: Radio Issue
Postby ZULU1 » Fri Nov 08, 2013 8:25 pm
I may add that the reason the vee rabbit performs is the fact that it actually doesnt need a ground plane at all. In your application, you may as well use a knitting needle if no ground plane is attached, the plate should be at least the size of half the length of the whip itself. Not getting technical but a dustbin lid is a good start..as long as its metal. No rocket science, as Gerrie says a coke can even works or a few car plates in a cross...
