Capacitor inside instrument Pod
Martinvt
Postby Martinvt » Tue Sep 17, 2013 1:41 pm
Hi there,
Can someone maybe explain why there are a Big Capacitor inside my instrument Pod?
I have seen it also on one or two other trikes but do not see the need for it.
It looks like the Positive from either the battery or the engine is connected to it on the one side, and on the other side is going to whatever needs power.
I want to sort out the "Kraai nes" of wires inside my pod and need to know the purpose of this capacitor.
Martin
Martin van Tonder
Aerotrike Safari
ZU-CIE
justin.schoeman
Re: Capacitor inside instrument Pod
Postby justin.schoeman » Tue Sep 17, 2013 1:51 pm
Helps kill radio noise. The simple generators used on the smaller engines produces charging pulses, rather than a continuous current. The battery does a fair job of damping these, but is not 100% perfect. The cap (usually) does a good job of getting rid of the rest. Remove the cap, and you will hear a continuous whine on the radio.
Postby nicow » Tue Sep 17, 2013 2:07 pm
justin.schoeman wrote:Helps kill radio noise. The simple generators used on the smaller engines produces charging pulses, rather than a continuous current. The battery does a fair job of damping these, but is not 100% perfect. The cap (usually) does a good job of getting rid of the rest. Remove the cap, and you will hear a continuous whine on the radio.
There's any way a whine on his radio :lol: -take it out ##
Martinvt
Postby Martinvt » Tue Sep 17, 2013 2:46 pm
(^^) (^^) (^^) :lol: :lol: :lol: :lol:
Martin van Tonder
Aerotrike Safari
ZU-CIE
Martinvt
Postby Martinvt » Tue Sep 17, 2013 2:59 pm
Thanks Justin.
So if I understand correctly. On the side the battery should be connect and the other side the electronic devices and the generator directly to the Battery. There is a whole lot of wires in there which I think half of them is not being used.
What is strange is that after the capacitor I am only reading 10 - 11V :shock:
Maybe this is because of all that extra wires.
Martin van Tonder
Aerotrike Safari
ZU-CIE
ZULU1
Postby ZULU1 » Tue Sep 17, 2013 3:05 pm
Should be mounted as close tomthe regulator as possible and rated at minimum 22,000uf at 63 volts wired between positive and negative. Dont take it out unless its blown up.
justin.schoeman
Postby justin.schoeman » Tue Sep 17, 2013 3:07 pm
Martinvt wrote:Thanks Justin.
There could be many causes. It would be best to take it to a professional. A substantial voltage drop could indicate a serious issue (either a poor connection, or too much current for the wire being used), which may also be a fire risk.
KFA
Postby KFA » Wed Sep 18, 2013 6:22 pm
The Cap will not bring the volts down, it is not a resistor, it evens the current and absorbs some of the alternator noise. It is connected to the bat pos and GND and like zulu said, the 22000uf will do the trick. Have the wiring checked by someone who knows what he is doing or read the manuals or do both.
