Hi
Die herth 3503 het begin met misfire van tyd tot tyd. Het plugs en plug drade vervang maar probleem het net groter geword. Vandag het hy net besluit wil nie start. Engine draai maar geen vuur.
Vermoet dit kan die computer box.(box het krag) wees maar weet nie hoe om dit te toets nie.
Enige een wat my asb kan inligting verskaf.
Hennie
hirth 3503 does not want to start
- Turbo
- Top Gun
- Location: TurboDirect the home of Garrett Turbochargers
Re: hirth 3503 does not want to start
hennies1
back to basics boet. Pull a plug and earth it to the head, and crank over the prop by hand (careful) maybe use one mag only. if there is spark, and fuel, she MUST start.
Hi. Engine been fix. The injector wires was in a sleeve with water in it. Drain and know ok.
Glad you sorted out the problem - agree with Turbo, if you are battling to start, take a plug out, if it is wet, then you have fuel, although it may be flooded. Then check with the removed plug, if you have spark, and you have not fiddled with the timing etc, she has to start.
- Turbo
- Top Gun
Glad to hear its sorted man!! Enjoy
