Car Question
Car Question
Postby Bundy » Wed Aug 14, 2013 7:23 am
Hi guys,
My Isuzu KB200i Fleetside started beeping at me a while ago with the battery warning light coming on on the dashboard. (the beeping sounds like a heavy vehicle reversing!)
I checked my manual and it said either the battery or the alternator are faulty. Both were checked and everything is fine. Battery 100% and alternator charging at the correct rate...
I took off my cubbyhole compartment to locate the source of the "beeping" which on the irritation scale, is about a 9.5... and discovered that the unit emminating this sound is a little electronic unit called the "Coolant Module"... does anyone have any idea what this module does? Engine temp normal and coolant level is right...I cant find any reference to it in the manual at all.
Any ideas?
Thanks,
German
Re: Car Question
Postby German » Wed Aug 14, 2013 5:55 pm
On top of your radiator on the left hand side(if you stand in front of the vehicle facing the engine) is a sensor which monitors the coolant level. This sensor should have been placed lower, but all you do is bridge the two wires and wolla!
Barberton Sparkie
Re: Car Question
Postby Barberton Sparkie » Thu Aug 15, 2013 7:12 am
Yes, bridge the 2 wires that goes into the harness from the sensor, but then you have to regulary check the coolant level. Like you would your oil level.
Hope that 9.5 comes down to 0 on the irritation scale. vhpy :lol: ^
The electrical farmer that flies.
ZU-DEX
ZS-WOE
ZU-CCR
ZU-EKP
Re: Car Question
Postby Bundy » Thu Aug 15, 2013 7:21 am
I owe you both a beer boys! (^^)
Wires bridged...problem solved. vhpy
Irritation Level now normal. :lol:
Robbie Shaw
Re: Car Question
Postby Robbie Shaw » Fri Aug 16, 2013 7:30 pm
Bundy wrote:I owe you both a beer boys! (^^)
Allan .... Buy Amarok * All will be good .....lol
Robbie Shaw. (Rhodie)
ZU-BJU. (Love Machine)
Airmanship No 1
HENNING JOHAN
Re: Car Question
Postby HENNING JOHAN » Fri Aug 16, 2013 8:01 pm
Got the same buzzzer!But is must be something to do with the temo.250 KB diesel 2006 Radiator with shark tooth.As the temp get to normal then the noise is gone.Is this the some problem?
Re: Car Question
Postby Bundy » Sat Aug 17, 2013 4:02 am
Robbie Shaw wrote: Allan .... Buy Amarok * All will be good .....lol
What.... you dont think I've got enough issues Rhodie?? :lol:
Nah...I love Ipoopoo's, they are the best bakkies! I've had Ford and Toyota in the past...both gave me kak... they still make Isuzu's out of steel. :lol:
HENNING JOHAN wrote:Got the same buzzzer!But is must be something to do with the temo.250 KB diesel 2006 Radiator with shark tooth.As the temp get to normal then the noise is gone.Is this the some problem?
Nee wat Johan...daai "module" is maar net getoor. There is nothing wrong with the thermo or the temp in my case. Still cant figure out why the freaking battery warning light comes on when your Coolant module is F@#cked?? Eish baas, hou? :?
Anyway, I've now bypassed the problem....Just wonder what will happen if the Oil Pressure light comes on?? It prob means my brake lights dont work! :lol:
Robbie Shaw
Re: Car Question
Postby Robbie Shaw » Sun Aug 18, 2013 8:38 am
Have you sorted the problem out ?
Airmanship No 1
