Anti-icing mods to Jabiru 2200
Wizzwheels
Found a flight school
Postby Wizzwheels » Tue Apr 09, 2013 12:27 pm
Hi All,
I was wondering if anyone can provide advice on preventing carb ice on the Jabiru 2200 engine ? The other question is how does one increase the hp rating without having to perform major 'surgery' on the engine.
Thanks. vhpy
German
Re: Anti-icing mods to Jabiru 2200
Postby German » Tue Apr 09, 2013 5:53 pm
Buy a Rotax
Dobbs
Postby Dobbs » Wed Apr 10, 2013 2:55 pm
German, your comment is not at all helpful :?:
Whizzwheels, I do not know too much about the Jab engines ito of getting more horses from them, however, blue printing seems to be a faily common option - although, I have no idea how much more power you will get. A friend of mine had it done to his engine, and the increase in power was enough to require that he got a coarser prop. The Jab factory down in the George area do this, so maybe give them a call, and the same applies to carb icing, I am sure they will have the answer.
Do not believe anyone who tells you Rotax do not suffer from carb icing, I can verify this from experience in my Bushbaby, although with the typical configuration where the engine is enclosed in a cowl, the air intakes sit up close to the fire wall which typically has hotter than ambient air, but under the right, or wrong conditions, it can occur.
Wizzwheels
Postby Wizzwheels » Wed Apr 17, 2013 7:31 pm
Thanks Dobbs.
Much obliged for your input. (^^)
bobthebuilder
Postby bobthebuilder » Thu Apr 18, 2013 7:25 am
Carb Heat perhaps?
Byron Kirkland
