Electric Starter for Rotax 503
Le Pou
Postby Le Pou » Fri Jan 04, 2013 8:46 pm
I am considering fitting an electric starter on the Rotax 503 I am using on the Flying Flea I am building but need to consider the effect on the Weight and Balance. Does anyone perhaps know what the weight of a Nissan 1400 starter is and also the weight of a suitable battery?
Le Pou
nickjaxe
Re: Electric Starter for Rotax 503
Postby nickjaxe » Sat Jan 26, 2013 11:32 pm
Hi I would be interested in what your using for your 503 starter sys...I'm in the UK and 503 starters a rare as rocking horse poo
Nick.
Le Pou
Postby Le Pou » Sun Jan 27, 2013 9:49 pm
Hi Nick,
I have not done anything as yet but I will be using a Nissan 1400 starter. There are threads on this site with photos which describe the set up. Basically you remove the pull-start and bolt on an aluminium plate which carries the starter on the side. Toothed pulleys to take an auto timing belt are fitted to the starter and the crankshaft. An extension is made for the crankshaft to carry the pulley and a sprag gear so that the starter is not dragged along when the engine takes. And that's about it but look up the threads. A lot of detail is given.
Roy
nickjaxe
Postby nickjaxe » Sun Jan 27, 2013 10:03 pm
Thanks Roy I will have a look....I do have one on my 503 sounds a similar setup but there are always guys looking for electric starter and there very thin on the ground over here.
Postby Tailspin » Wed Feb 06, 2013 12:57 pm
Roy
If you can make me a set of Drawings i can get an Engineer to make up the plate then we can put the rest together. Will be cheaper if we make about 5 or so.
Gavin
Le Pou
Postby Le Pou » Wed Feb 06, 2013 9:50 pm
Hi Gavin,
At this stage I have got nothing, only the idea, and it will be some months before I will look at it. My brother in law has suggested using auto plastic timing pulleys which might be cheaper than aly but it is all pie in the sky at present.
Roy
HENNING JOHAN
Postby HENNING JOHAN » Thu Feb 07, 2013 8:10 pm
somebody told me that Morph had a great stater for the 503.If only we can get hold of him? (^^)
Postby Boet » Thu Feb 07, 2013 10:11 pm
Or try "Skidmark", he makes them. vhpy
Jon Hewitt
Postby Jon Hewitt » Tue May 13, 2014 10:58 am
hi
i have a windlass 503 pull start , would like to install electric start , how do i get hold of "skid mark"
cheers
Jon
Postby Jean Crous » Tue May 13, 2014 7:24 pm
This should then also be able to work on a 582 with a "c-box" , if one removes the pull-start ?
Jean.
HENNING JOHAN
Postby HENNING JOHAN » Tue May 13, 2014 7:54 pm
I know that Alpha showed me his electric starter on his 503.
Jon Hewitt
Postby Jon Hewitt » Wed May 14, 2014 9:50 am
HOW DO WE GET HOLD OF SKID MARK ,OR SOME ONE WHO COULD ASSIST
JON
