What Spark plugs !!!
Bennie Vorster
Postby Bennie Vorster » Tue Apr 18, 2006 3:09 pm
What Spark plugs is the best to use on my 503 Rotex The ones that is fitted curently is the NGK DR8ES.
Somyone advised me to rather fit NGK DR 8 EA at around R55.00 per plug. :shock: :shock: :shock:
And just how long will these plugs then work. :roll: :roll: :roll:
Bennie Vorster
083 277 5110
kb
Postby kb » Tue Apr 18, 2006 3:10 pm
BR8ES, that's what I run on, also a 503
Thunderboy
Re: What Spark plugs !!!
Postby Thunderboy » Tue Apr 18, 2006 3:22 pm
Bennie Vorster wrote: And just how long will these plugs then work. :roll: :roll: :roll:
I thought you had to replace them every 25hours on the Rotax 5 series :?:
Correct me if I'm wrong :oops:
Bennie Vorster
Postby Bennie Vorster » Tue Apr 18, 2006 3:24 pm
kb wrote:BR8ES, that's what I run on, also a 503
No Stock here on the farm. :? :? :?
Bennie Vorster
083 277 5110
ICEMAN
Postby ICEMAN » Tue Apr 18, 2006 3:24 pm
Same here: DR8ES on a 503
ZU-CPW..... t/bird mk2
Hoedspruit Civil Airfield
Hangar 8
Bennie Vorster
Postby Bennie Vorster » Tue Apr 18, 2006 3:26 pm
Does'nt it depend on the type of plugs as well? :? :? :?
Bennie Vorster
083 277 5110
Thunderboy
Postby Thunderboy » Tue Apr 18, 2006 3:45 pm
Checked their website and:
"The best guide is the manufacturer's recommendation for your vehicle, as this particular service varies from brand to brand and model to model."
But anyway go to http://www.ultralightnews.ca/articles/r ... kplugs.htm
There are pitures and info there on when to replace :wink:
Postby Morph » Tue Apr 18, 2006 3:57 pm
BR8ES or BP8ES
The BR help overcome EMI inteference with the ignition system and your radio. I have used both and haven't really noticed any difference, but then again I didn't have a problem in the first place
Plugs should be replaced every 25 hours, but I do know of people who only replace the the left two on each piston and then the right two getting an effective life span of 50 hours per plug.
Me, I've just religeously stuck to the 25 hour thing as the plugs are not that expensive. About R20 each I think.
Postby Duck Rogers » Wed Apr 19, 2006 9:50 pm
Bennie, the BR8ES or BP8ES is the standard, recommended plug by Rotax for your engine.
The BR8EA will not harm your engine at all. It has a V-groove in the electrode tip and is supposed to give better ignition with a better spark flame. It burns at a good temperature at any throttle selection. The theory is that if you've been at say, half throttle for a while, and you suddenly open the throttle, it will burn the sudden increase in fuel/air mixture effectively enough to respond immediately. It's a special racing engine plug that's why it costs around R55,00 each.
Picture of the EA plug:
I use the NGK BR9EIX plugs. It has a colder range and is also a racing plug. It has better ignition properties than the EA plug and can withstand fouling and leaner mixtures better. Just a little safety factor for my engine :D It also dissipates heat more quickly so the combustion chamber doesn't get as hot as with a normal standard heat range plug. The heat generated has to go somewhere though, so it is being transferred into the cylinder head where the radiator coolant takes care of it (582, water-cooled) :D
It also starts my engine quicker because the engine is inverted and is prone to wet-fouling.
They also cost in the region of R60,00 each :shock:
Picture of the EIX plug:
It's probably overkill for our application, but I feel better :roll:
The Agentman will know all about the importance of racing plugs :D
Aerosan
Postby Aerosan » Thu Apr 20, 2006 7:43 am
Duck where did you get these?
Bennie Vorster
Postby Bennie Vorster » Thu Apr 20, 2006 8:48 am
TX Duck I'LL get some today. :wink:
Bennie Vorster
083 277 5110
Postby Duck Rogers » Thu Apr 20, 2006 9:34 am
Aerosan wrote:Duck where did you get these?
They're not available in SA. At least not in the places I tried to source them from :x I got them from the same place as I got the primers from...ie. imported from the USA.
Bennie Vorster
Postby Bennie Vorster » Thu Apr 20, 2006 2:08 pm
The DR 8 EA you will find from most Bicke repair shops. :wink:
Bennie Vorster
083 277 5110
