Hi guys,
The comms on my trike are playing up a bit, i am using a buzzcom intercom, vertex radio, does anyone have a wiring diagram for a system like this, i suspect a bunch of dry connections, and in the case of the connection that goes onto the radio a damaged wire inside the sealed plug.
any information gladly welcomed
Comms problems
- Lesser_spotted_owl
- Got my wings at last
Comms problems
ZU-CRC Cobra
ZU-CRC Cobra
- ZULU1
Re: Comms problems
LSO, this is what we advise to the UK converting a Icom plug to a CT96 (supplied with radio) hence Maplins part numbers but it will give the pin out and comparison to the Icoms. The VXA220 is possibly the best radio available at present and is superior to panel mounts so it should work well.
Zulu1
Zulu1
- VXA 220 to Icom.pdf
- Conversion chart
- (42.73 KiB) Downloaded 334 times
Re: Comms problems
Hallo,Lso!Buy yourself a airmagic system!Ask Porra about it!Ask to borrow his system and check the great coms!
I did and make me a believer!
Re: Comms problems
Thanks Paul,
Thats exactly what i was looking for, I know there is a bad connection in that plug from a 'fiddle fix' but wasn't sure what all the wires were for.
Much appreciated
Hey Johan, as much as i would like an airmagic system, (and i would, already have the bunny aerial) the system we have is not completely toast yet, it's just a bit moeg and needs some love
Much appreciated
ZU-CRC Cobra
ZU-CRC Cobra
Re: Comms problems
In my case the bigger the problem the bigger the hammer!!Lesser_spotted_owl wrote:Thanks Paul,
Much appreciated
