Rotax 503
- John Boucher
Re: Rotax 503
Where's Duck Rogers when you need the man?
From Rotax website...
Performance
Maximum power 49.6HP / 37.0kW @6500 RPM (I suppose this would be MAX Continuous?)
Maximum torque 41.3ft-lb / 56NM @6000 RPM
Maximum RPM 6800 RPM
http://www.challengers101.com/IntakeTuning.html
Performance
- Duck Rogers
Re: Rotax 503
Busy making money so I can buy the groceries.....John Boucher wrote:Where's Duck Rogers when you need the man?
John is right..........6500 rpm continuous
and
6800 rpm max for 3 mins (normally on take-off, if required)
- Leprachaun
Re: Rotax 503
Ditto jy kan hom maar gas gee - it doesnt like to run effiently below 6000 rpm - below torque curv Leprachaun
- BOOMARANG
- Survived first engine out
Re: Rotax 503
While Duck is dispencing his pearls of wisdom.....can I ask the same question for a 582 Blue Top ?
BOOMARANG
- John Boucher
Re: Rotax 503
6000 rpm max continous for the 582
- BOOMARANG
Re: Rotax 503
Thanks John. And since Duck is earning crocery money, could you please tell me what the max revs ( i.e 6800 for 3 min for the 503) for the 582 will be ?John Boucher wrote:6000 rpm max continous for the 582
Cor
BOOMARANG
- John Boucher
Re: Rotax 503
http://www.rotaxservice.com/documents/582info.pdf
http://www.rotaxservice.com/documents/582perf.pdf
6800rpm max for 1 min
Re: Rotax 503
Performance
John
Thanks for the VERY useful link to the Challenger site!!!
Have been searching for an active and resourceful online community and this seems promising!
Much appreciated!!!
Len M
The knack [to flying] lies in learning how to throw yourself at the ground and miss.
- John Boucher
Re: Rotax 503
Hey guys ... that's why we come to microlighters.co.za ------ to help each other!
Re: Rotax 503
Sorry for the hijack, what or where is Morph?
- John Boucher
Re: Rotax 503
Greg is busy with a serious project which is demanding a lot of his time. Note that he does keep an eye on the forum behind the scenes though. His infinite wisdom is however missed in so many avenues. I don't want to speak on his behalf though.....
In short, we DO MISS HIS PRESENCE, POSTS & PARTICIPATION!
Re: Rotax 503
