MGL Xtreme EFIS
- Air Hog
- The Boss
MGL Xtreme EFIS
I am very exited, got my new MGL Xtreme Mini EFIS today from MGL. Can't wait to fit it this weekend. Have ordered it for the Thunderbird but will fit it to the Aquilla in the mean time.
Re: MGL Xtreme EFIS
http://www.mglavionics.co.za/Infinitec/XTreme.html
*drool*EFIS:
Attitude display. Note (1)
Magnetic heading indication. Note (2)
Heading bug
Precision altimeter from –1000ft up to a maximum of 30 000ft (-304m to 9144m). Altitude can be displayed in ft or m
Altitude bug
Airspeed indicator (16mph to 250mph), 1mph resolution. Airspeed can be displayed in mph, km/h or kts
Digital VSI indicator (+/-20 ft/min to +/-10 000 ft/min) and analog VSI indicator (+-2000 ft/min range). VSI can be displayed in ft/min or m/s.
Serial Altitude encoder output via a RS232 port
Density altimeter
OAT (Outside Air Temperature) display using an external OAT probe
Supply Voltage display
Stopwatch timer
Automatic flight timer
RTC (Real Time Clock)
* Glide and climb ratio indicator
Barometer (actual local pressure)
TAS (True airspeed) display
G-Force indication. Note (1)
Wind speed and wind direction indication. Note (2)
Turn Indicator. Note (1)
Slip/Skid indicator. Note (1)
GPS flight path (GPS calculated bank and pitch angles)
Engine Monitor: Note (3)
1x Engine RPM
1x Rotor RPM
1x Manifold pressure
1x Oil pressure input
1x Oil temperature input
2x Auxiliary analog channels (Pressure/Temperature/Current)
12 Channel EGT/CHT display
2x Fuel Flow
2x Fuel Level
Programmable maintenance timer for scheduled routine engine maintenance
Engine display screens are automatically configured to optimize screen space depending on what
parameters are been displayed
Settable Hobbs meter (password protected)
Fuel range / endurance based on TAS or GPS ground speed
Current monitor to measure charge/discharge currents. Note (4)
Engine leaning feature
General:
Alarms on most displays
Programmable airframe timer for scheduled airframe maintenance.
Records maximum and minimum values of most displayed values
Built in black box recorder – records all flight data, engine, attitude and GPS data to SD card. Data can be
exported to Google Earth, Microsoft Excel, etc.
Includes a 1000 entry automatic flight log (Records start date&time, flight time, pilot number, Hobbs time,
maintenance time, max altitude, airspeed and VSI reached during the flight)
User configurable start up (Splash) screen
Unlimited configurable checklists
Unlimited configurable graphic information displays
Automatic or manual local magnetic variation
Dual menu system for quick item selection and user setups
Sunrise/Sunset calculator
Firmware upgrades via SD Card
1 year limited warranty
(1) Requires optional MGL Avionics AHRS sensor unit (SP4/SP5)
(2) Requires optional MGL Avionics compass sensor unit (SP2)
(3) Requires optional MGL Avionics RDAC unit
(4) Requires optional MGL Avionics current monitor sensor
- Air Hog
- The Boss
Re: MGL Xtreme EFIS
And, the basic instrument without the Optional stuff at the price of a GPS.
The RDAC is standard with the system although it shows optional.
Re: MGL Xtreme EFIS
Price please?
Flew behind one in a SINUS a while back, but they were still playing with GPS and RDAC was extra then. Looks awesome. Does it have the GPS functionality yet? (Heading and ground speed)
- Air Hog
- The Boss
Re: MGL Xtreme EFIS
Basic system R7805 shipped to Pretoria. Does not have all the funtionality of GPS yet, but ground speed and heading working like normal GPS. Free upgrade later in the year as promised, to get all GPS functions working.
Re: MGL Xtreme EFIS
Eish, that is awesome value. Am tempted.....
- Relborg
Re: MGL Xtreme EFIS
Is it waterproof so that it can be fitted to a trike?
Dirk Grobler
http://www.jhbflying.co.za
- Air Hog
- The Boss
Re: MGL Xtreme EFIS
What I understand it is not "Dunk Proof". I am fitting mine to a Aquilla Trike on a T-Pod, so it is out of the weather but still exposed.Relborg wrote:Is it waterproof so that it can be fitted to a trike?
Check this link http://www.mglavionics.co.za/Infinitec/XTreme.html
I am not an Agent for them, just exited about it.
- nicow
Re: MGL Xtreme EFIS
Looks great-I want one on my trike.
Re: MGL Xtreme EFIS
I will def buy one, Stefan hoop jy lees die want raai wie gaan dit insit
Flying feeds the soul!
Re: MGL Xtreme EFIS
Just to confirm the price is for the unit without these add ons?Air Hog wrote:Basic system R7805 shipped to Pretoria. Does not have all the funtionality of GPS yet, but ground speed and heading working like normal GPS. Free upgrade later in the year as promised, to get all GPS functions working.
So in other words all the functions (with the numbers next to them as per justin.schoeman post) will not work?
Re: MGL Xtreme EFIS
Yes on 1,2 &4. 1 is MOER expensive.
RDAC was not included when I asked for pricing but that about R1200
Air Hog wrote: The RDAC is standard with the system although it shows optional.
Re: MGL Xtreme EFIS
Only reason I have doubts is I have to cut a new panel. Anyone know who does ali panels in Jhb/Pta? I have a cad drawing for template.
