Specifications
Excluding VAT Including VAT
R87 719.00 R100 000.00
This Entry-Level Trike Features the Following:
ENGINE: 503, 2 stroke 50 HP, air cooled, dual cylinder, dual carburetor
REDUCTION: Rotax B-type gearbox 2.58:1
TANK: 50 litre custom made polyethelene tank.WING SPAN 10,5 meters
EMPTY WEIGHT 150 kg
MAXIMUM PAYLOAD 200 kg
FUEL CAPACITY 50 litres
FUEL RATING
95 / 97 octane
PERFOMANCE
TAKE OFF ROLL - SOLO 40 meters
TAKE OFF ROLL - DUAL 60 meters
RATE OF CLIMB - SOLO 7 meters per second
RATE OF CLIMB - DUAL 5 meters per second
STALL SPEED - SOLO 40 kph
STALL SPEED - DUAL 52 kph
CRUISE SPEED 70 – 100 kph
FUEL CONSUMPTION - SOLO 8 litres per hour
FUEL CONSUMPTION - DUAL 10 litres per hour
DESIGN LOADS - POSITIVE 6 g’s
DESIGN LOADS - NEGATIVE 3 g
EMPTY WEIGHT 150 kg
FUEL RATING
INSTRUMENTS & POD: see optional extra’s
WING: Aquilla high performance wing with your choice of 14, 15, 16.5 or 17.5 sqm wing
PROPELLOR: 2 blade, 1.65m hand crafted wooden propellor
http://www.solowings.co.za/products/windlass.php
New Windlass trike Specifications
- Bennie Vorster
Bennie Vorster
083 277 5110
Bennie Vorster
083 277 5110
