I took off with the hand throttle full blast as I usually do, as I reached cruising altitude I eased up on the hand throttle only to find the plane still at max rpm and climbing at 1000 fpm - Checked if my shoe was engaging the foot-throttle and it was not
Not too big of a deal - Made a call on the radio stating I am in trouble and need to do a dead-stick, ensured I had enough altitude and I then cut the mags, and all electrical power before doing a maneuvre I practiced numerous times above the same runway. Landing was no problem
Upon inspection we found the throttle cable to be stuck in open position completely - I am not technical at all so am not going to make like I know what caused it, it was just stuck - Period
Best bet probably to get Rotax-pro to replace all the throttle cables?
D
