P-Prop Problem?
du Plessis
Found a flight school
P-Prop Problem?
Postby du Plessis » Sun Nov 22, 2009 11:22 am
Hi everyone....
Is there any professional opinions on my proplems with p-prop. It seems like the wood on the end-tips of the prop are pulling apart. Its been this way since I bought the trike (about 35 flying hours ago), and a lot of 'unprofessional' opinions at our small airfield says 'not a big problem'..... But it is starting to worry me now.
Any opinions on this? And where to fix if needed... And cost more or less.....
All help appriciated...
Thanx!!!
P.S. Sorry about photo quality... cell phone was only camara...
KFA
Re: P-Prop Problem?
Postby KFA » Sun Nov 22, 2009 11:46 am
That prop has def been repaired.You can use some two part epoxy to fill the gap and the file or sand it down again. You might get a balancing propblem if you have to use a fair amount of epoxy. Best will be to send the prop to Oom Piet himself for repairs. Not sure about the cost but usually between R1500 and 2k if you want it done properly. Call him on 011 7935235
Low Level
Re: P-Prop Problem?
Postby Low Level » Mon Nov 23, 2009 8:45 am
Yip - gaan sien vir oom Piet self - hy bou die P-prop. A wealth of knowledge. Hy werk van sy huis af in Randburg.
ZU-CFW
du Plessis
Re: P-Prop Problem?
Postby du Plessis » Mon Nov 23, 2009 3:32 pm
Baie dankie vir jul 'info'!! Ek gaan hom beslis kontak.
vhpy
Re: P-Prop Problem?
Postby RV4ker (RIP) » Mon Nov 23, 2009 4:39 pm
Had similar on KR prop. oom piet sorted it out 1 shot. K@K praat for 5 hrs was a bonus... (^^) (^^) (^^) (^^) ($$) ($$) ($$) ($$)
HWduPlessis
Heard about flying
Re: P-Prop Problem?
Postby HWduPlessis » Thu Nov 26, 2009 4:47 pm
Is it the photo only or do I see ur hand trembling? Agree with all the helpfull replies. I gather you r not near a "repair" shop? U a Zim citizen? vhpy
