Sjydat GX2 Fuel level settings
pietmeyer
Postby pietmeyer » Tue Sep 29, 2009 4:10 pm
I hav a Skydat GX2 fitted on my trike. I need to callibrate the fuel level. Does anybody know how this is done?
Piet Meyer
Jabi J400 ZU-DUU (Wonderboom)
Tracer
Re: Sjydat GX2 Fuel level settings
Postby Tracer » Tue Sep 29, 2009 6:41 pm
Not sure about the SJydat GX2, but I am sure if you phone Amptronics, they may be able to tell you how to calibrate the SKyDat GX2 (^^) ##
pietmeyer
Postby pietmeyer » Thu Oct 01, 2009 5:16 am
And all this time I have been flying with the wrong instrument. The Sjydat is the cheap "Made in China" knock-off. That should also explain why my "Preitling" watch is not working either. That little bastard that sold me all of this at the robot was lying when he said "brands names realy cheap, only 5 dollar" Should I be worried about my Rotaz motor?
Piet Meyer
Havoc
Postby Havoc » Thu Oct 01, 2009 4:54 pm
Piet,
omdat die tenk die "shape" het wat dit het is dit onmoontlik om die kalibrasie 100% te doen, en natuurlik die rede hoekom ek die persentasie sticker op die kant van die GX2 gesit het.. groente... flo
hi this is flo welcome, come try us
Tracer
Postby Tracer » Thu Oct 01, 2009 5:41 pm
pietmeyer wrote:And all this time I have been flying with the wrong instrument. The Sjydat is the cheap "Made in China" knock-off. That should also explain why my "Preitling" watch is not working either. That little bastard that sold me all of this at the robot was lying when he said "brands names realy cheap, only 5 dollar" Should I be worried about my Rotaz motor?
At least with the Rotaz motor, you won't need to worry about the 300hr crank inspection or 600hr overall. Just run it till it dies, then fix it (^^) (^^)
gertcoetzee
Postby gertcoetzee » Thu Oct 01, 2009 8:22 pm
Piet,
When I got ZU-DVE 4 years ago, I contacted both Amptronics and Solowings when I found that the gauge was not calibrated correctly. I am still waiting for an answer.
In the end, I know that at 75% the tank is half full, and at 30% I need to look for a landing spot.
Massimo
Postby Massimo » Sat Oct 03, 2009 10:28 am
Speak to Surge at Amprtonic. 0116792754, he is fairly helpful. As far as i know as long as you have the corerect inlet reducer in your fule flow then it should be calibrated. Otherwise send the whole thing to Surge and he will do it for you.
