Hi there all you knowledgeable folks
I have a trike with a 503 engine and a B Gearbox and a wood P prop
I have recently purchased a E gearbox.
Will I need to change my Prop?
I await your wisdom
Do I need to change my prop
How do mosquitoes get this high?
Re: Do I need to change my prop
Which ratios?
B Box ratios 2.0/2.24/2.58
E ratios 2.62/3.0/3.47/4.0
I would say yes unless you are changing from the 2.58 to the 2.62 which is quite close
The higher ratio, is allowing you to spin the prop slower for the same rpm as before, eg if you had the 2.0 then 6000rpm would give you 3000 on the prop, now 6000 on the 3.47 box will give you 1720rpm on the prop, which will allow for a longer fatter prop, or higher pitched prop, unless of course you have a ground adjustable prop like a warp drive, then you will have to change the pitch your self.
I have 2.62 gears for the E-Box if you need it.
R4500.00 new BUT WAIT if you act now, you can have it for 4500.00 Zim dollar.
That`s right 4500 Zim dollar.
Thanks for the offer Paul, but would rather not change the ratios...
Thanks for the explination Morph...
I love microlighters, you always get an answer to your question!
Just finished reading the thread below about wood vs warp so its off to the shop...
Phil
Phil
